Old 05-05-2018, 02:21 PM   #1
Jmaverickg
Jmaverickg has a spectacular aura aboutJmaverickg has a spectacular aura aboutJmaverickg has a spectacular aura about
Default 07 Outlook Water Pump Removal
Any help would be appreciated! I have an 07 Outlook XR and in mid water pump replacement, and I say mid because I can't figure out how to get it out of the car. It's removed from the engine but stuck in between the frame rail and it's seat. Any help or instructions on how to physically pull it out so I can start the re-install process would be greatly appreciated.
Add to Jmaverickg's Reputation
Rate the quality of this post and help Jmaverickg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jmaverickg is offline   Reply With Quote
Old 05-05-2018, 11:26 PM   #2
Jmaverickg
Default Re: 07 Outlook Water Pump Removal
Figured it out! Lost some skin, but got it out! In case someone needs to know, push the old pump up toward the top of the engine/frame rail and you can wiggle and flip it over with the impeller pointing outward and then pulls mound in toward the engine. After that, lower it down and it will easily slide out between the lower pullys. Do the opposite to put the new one in. Good Luck!
Old 05-06-2018, 12:59 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Glad you got it..
Add to onefunkar's Reputation
Water pump removal Mxer0022 Ion Tech 3 08-19-2016 11:31 AM
replacing 2007 outlook water pump grnmax7 Outlook General 5 06-05-2014 10:00 AM
Water Pump Removal turbosaturnsl2 S-Series Tech 15 09-06-2011 11:12 PM
Water Pump Removal MDSaturnSL2 S-Series General 5 07-30-2004 10:41 PM
Need help with a water pump removal. Flyguy405 Miscellaneous Tech 3 12-11-2003 02:36 AM
