Old 04-25-2018, 08:56 PM   #1
Petey
Petey is on a distinguished road
Petey's Avatar
2004 VUE 3.5L
Default 3.5 Vue with conflicting codes
I'm puzzled with 2 codes our 04 Vue threw today. I am not sure if they were thrown at the same time but they both came today.
P0446 and P0455
How can it be holding pressure too long and detecting a large leak?
A sticking vent solenoid?
A faulty tank pressure sensor?
97 SL2 5-speed 190K, black & gold w/ gold trim, power package, sunroof, spoiler
06 TrailBlazer 90K
Add to Petey's Reputation
Rate the quality of this post and help Petey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Petey is offline   Reply With Quote
Old 04-26-2018, 02:53 AM   #2
Default Re: 3.5 Vue with conflicting codes
If not close to state emissions inspection, you can try resetting these error codes and see if one or both return. In the meantime the two links (below) may help.
Here are the two error codes as described in technical details;
DTC P0446 - https://www.obd-codes.com/p0446
DTC P0455 - https://www.obd-codes.com/p0455
The vent valve is usually the one mounted near the fuel fill pipe, hiding behind the quarter panel. A separate evap line goes to this vent valve to allow tank venting while filling the tank. Its powered with 12v to close along with the purge valve opening to allow the engine to suck vapors collected in the charcoal canister for recycling into the engine intake. Vent valves, tank fuel pressure (and vacuum) sensor and evap purge valve are usually reliable and last the life of a vehicle unless damage occurs from crash incidents. The fuel tank pressure/vacuum sensor only measures one or two psi and vacuum less than 15in hg for the evap system. If there's anything that can trigger one or both error codes, possibly indicating more than one problem, it may be severely corroded metal lines used in the evap system. One line may be the vent line to the vent valve running next to the fuel filler pipe. An examination of the fuel fill and vent pipe may reveal the extent, if any, of severe corrosion allowing metal pipes to erode, opening the line to outside air. When eroded, the evap system cannot seal to test tank pressure and vacuum resulting in error codes. Rubber hoses, damaged plastic fittings, are also considered in finding the cause of these errors. Testing solenoid valves are simple and described in both links.
Old 04-26-2018, 06:01 PM   #3
Petey
Petey's Avatar
2004 VUE 3.5L
Thanks, I read the FSM deff. on setting P0446 wrong. I read it as it sets the code if Vacuum is held longer then set amount of time. It now makes sense.
Question is this now.
How reliable are NAPA caps? that i think is the problem. On Tuesday she could not put gas in it because the cap just spun and did not come off. I go a new one at NAPA because its way out of the gas cap warranty from GM.
And the codes came on on Wednesday.
06 TrailBlazer 90K
Old 04-26-2018, 08:28 PM   #4
Aftermarket gas caps must meet OEM specs to work. Check for compatibility otherwise shop for a GM cap (online if local stores don't have one). Your local GM dealer may have one too.
Codes codes and more codes 99sl2 Jaybone586 S-Series Tech 4 06-06-2015 09:21 AM
SES Codes. Snakebit S-Series Tech 13 01-08-2012 01:07 AM
OBD I codes sat-vic S-Series Tech 19 12-07-2008 01:14 AM
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no bskicrash1 S-Series General 2 11-12-2006 02:10 PM
SES Codes (beyond the paperclip codes) rkhassen S-Series Tech 11 10-18-2006 08:53 AM
