Old 04-24-2018, 01:58 PM   #1
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Saturn Patents
Some interesting browsing:
https://patents.google.com/?assignee=Saturn+Corp
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 04-24-2018, 05:05 PM   #2
Default Re: Saturn Patents
Cool stuff, thanks for posting that. Downloaded the PDF for the subframe nut thing as that may be in my future
Incredible that they patented the plastic valve covers
Old 04-24-2018, 06:20 PM   #3
Cheyne
2000 SL2
Incredible that they'd bother. FAIL.
Add to Cheyne's Reputation
Old 04-24-2018, 06:46 PM   #4
toggenburg
toggenburg's Avatar
Not all plastic ones are the same, my 98 SW2 never warped or leaked with over 215K miles on it.
Old 04-24-2018, 06:48 PM   #5
Eiron
Eiron is on a distinguished road
Eiron's Avatar
1999 SW2
At least it's just a cover and doesn't cause engine failure. Ford's "better idea" was bolting a plastic thermostat housing directly to the engine block and flowing hot, pressurized coolant thru it! We had to replace that stupid thing on my daughter's Focus three times in six years!!
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 04-24-2018, 07:12 PM   #6
Cheyne
2000 SL2
Been there, done that on my son's Explorer. Not to mention the plastic "diverter" or whatever it's called fail in the heater hose on the 4.0.
But ... GM also used plastic fittings in their coolant lines at the block. I don't remember the exact configuration, but I had to replace one on the brother-in-law's Bonneville that was a common failure causing the coolant to pour out.
I wonder if Ford tried to patent theirs.
Old 04-24-2018, 07:16 PM   #7
Cheyne
2000 SL2
I think this has to do with not allowing to overheat. I have a 2000 that I promptly replaced the radiator when it first showed signs of leaking. I tend to check the coolant whenever I check oil. I also replaced the cam cover gasket when oil showed up in plug 1. It doesn't appear to be warped, and there's no sign of leaking on visual/blotting inspection.
Either way, I'd much prefer an aluminum valve cover if we could get one for 3rd generation.
Food for thought: Saturn patents J N Winkler General Saturn Discussion 1 12-28-2014 11:36 PM
Saturn Racing Group Saturn Show at Saturn of Tempe ry92sc Events 7 01-23-2005 09:38 PM
