Go Back   SaturnFans.com Forums > Categories > Classifieds
Old 04-23-2018, 10:19 AM   #1
MrWhsprs
MrWhsprs will become famous soon enough
MrWhsprs's Avatar
2000 SL2
Default FS: 2000 SL2 w AEM intake, Eibach springs
2000 SL2
197K miles
Located in ZIP 60073
$800.00
Auto trans, alloy wheels, 2 keys & fobs, pwr door locks, pwr windows, pwr outside mirrors, A/C, engine block heater (very helpful for winter!). Sony head unit w Bluetooth, CD, USB, etc.; remote control & manuals included. Everything works as of last time I tried them. Passed IL Emissions in Oct 2017.
Fuel economy: My average over the past 2 years has been 38 mpg, with a commute of 40 miles, driving moderately.
AEM intake + filter installed. Bottle of AEM filter cleaner included. Factory air intake also included. Eibach lowering springs installed. Factory springs also included. Hidden radio antenna mod. Side marker turn signal mod. Headlight bulbs HIR1 (9011) and HIR2 (9012) new in late 2017.
Supplies included:
~7qt Mobil1 5W-30 High Mileage oil; 2 Wix extra-capacity oil filters; oil plug gaskets. (Last oil change at about 193K miles so itís due.)
~3.5qt Amsoil Torque-Drive synthetic trans fluid; 1 Wix transmission filter
Various spare parts included: EGR, ignition coils, plug wires, PCV valve, IAT sensor, throttle body gaskets, lower air dam.
Various items over past 60K miles: 193K: Spark plugs. 190K: Michelin Premier A/S tires. 184K: Exhaust (all behind cat.). 182K: PCV valve. 173K: Brakes. 168K: Plug wires. 167K: Upper motor mount. 165K: Trans fluid & filter. 160K: Exhaust (down/flex & cat.). 155K: LF knuckle/hub/bearing. 150K: Radiator, thermostat, serpentine belt. 141K: RF knuckle/hub/bearing.
Oil usage is about 1qt/800-1000miles, with moderate driving. When temp is bitterly cold, trans can hesitate to shift into 1st gear. Best to use the block heater, and/or start the engine and let the trans warm up a bit.
There is front end damage, various paint flaws, rust spots. Inside, the center console lid hinges are broken (hinges are included). The DLC port came off the bracket so is tucked up under the steering column. The port still works fine (I know as I was running a ScanGaugeII off of it).
<>< Mike
*FOR SALE*: 2000 SL2: 197,0xx mi 2018-04-19. (Replaced with 2010 Toyota Prius)
1999 SW2: 269,454mi when totaled 2014-06-14. (Replaced with 2006 Ford Escape Hybrid)
Add to MrWhsprs's Reputation
Rate the quality of this post and help MrWhsprs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrWhsprs is offline   Reply With Quote
Old 05-12-2018, 05:35 AM   #2
MrWhsprs
MrWhsprs's Avatar
2000 SL2
Default Re: FS: 2000 SL2 w AEM intake, Eibach springs
Still available.
<>< Mike
Eibach springs alleninpa S-Series Mods 3 09-26-2011 06:06 AM
Eibach springs SaturnSL2Guy S-Series Mods 22 09-02-2010 10:16 AM
Eibach Springs bulld0g Aura General 53 11-15-2007 05:42 PM
Eibach Springs and a SW2 ? Help! VEGAS_SATURN S-Series Tech 5 05-21-2006 06:14 PM
Eibach springs available LUKass Ion General 5 01-06-2004 02:32 PM
