Old 04-22-2018, 08:57 PM   #1
rcote20
rcote20 is on a distinguished road
2003 ION-2 Sedan
Dizzy Power steering stiff after changing alternator??
Just curious, in January my alternator went bad. It was replaced with a used unit. Ever since, everything works as normal (no battery lights, no issues at all) EXCEPT for the power steering. It's working, but not a well as before. Could this alternator not be putting out enough power? Is there something I need to do after the battery goes dead to reset it? Not quite sure where to go from here! Car is an 03 Ion Sedan Level 2, 2.2L automatic.
Add to rcote20's Reputation
Rate the quality of this post and help rcote20 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rcote20 is offline   Reply With Quote
Old 04-23-2018, 09:50 AM   #2
Default Re: Power steering stiff after changing alternator??
There may be several reasons for erratic power steering; wiring to the eps unit, worn dc motor, insufficient/erratic power, loose drive belt/worn belt tensioner, worn alternator. Is the drive belt tight? Can you measure battery/alternator voltages? Good batteries should be around 12.5v. Engine idling voltages should be higher, between 13v-15v. Observe voltages while someone turns the steering wheel several times. Voltages should not drop below battery voltage. Raise idle a little higher and observe voltages while turning the steering wheel.
Since electric power steering relies on alternator power, a used alternator may not output enough power. In addition to measuring output voltages, store testing may help. Some stores can test battery and alternator in the car while others need them removed for bench tests in the store. Last is the possibility of a faulty or worn dc motor in the eps, wiring or faulty eps unit. Search for electric power steering issues and a link to articles about worn out dc motors.
Alternator with 210k miles & possible power steering fluid contamination Upstate Saturn S-Series Tech 4 11-20-2014 10:06 PM
Changing your Power Steering Fluid -- tool tip hholbein S-Series Tech 29 11-10-2010 09:24 PM
Question about changing the power steering fluid? turbobuick33 S-Series Tech 2 07-27-2007 11:07 AM
Power Steering Pump and Alternator Problems - Whining noise and Burning Smell batmobile S-Series Tech 14 08-03-2006 12:29 PM
power steering fluid on alternator geartooth94 S-Series Tech 9 05-23-2005 11:29 AM
