Old 04-22-2018, 03:56 PM   #1
raymondjiii
raymondjiii is on a distinguished road
1994 SC2
Default I see some serious sub-frame rust
My rust is on the drivers side "big flat piece" that curves down from the engine area. The passenger side is in perfect shape. I know sometimes these cancers set it and run wild. I saw some posts about people replacing there's but I could not determine if anyone has actually done it and if so - where one might get the parts (besides a junk-yard.)
Add to raymondjiii's Reputation
Rate the quality of this post and help raymondjiii reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raymondjiii is offline   Reply With Quote
Old 04-22-2018, 04:32 PM   #2
Kaervak
Kaervak will become famous soon enoughKaervak will become famous soon enough
Kaervak's Avatar
Default Re: I see some serious sub-frame rust
It's a fairly straightforward swap. A dozen or so bolts, most are pretty obvious but a couple ground connections are kinda hidden. Have to unbolt the power steering rack from the subframe. You'll need to support the engine and radiator/condenser from the top before removing the subframe though. Oh yeah, have to remove/disconnect the downpipe. That's in the way while removing the subframe. Plan an entire day, maybe two. While you're in there, replace your control arms and stabilizer bar bushings too. I got my replacement from a wrecking yard in Utah on ebay. $300 or so shipped if I remember right. Not a spot of rust anywhere on it which was nice. Impacts, breaker bars and oxy/acetylene are your friend. Take your time, don't rush things and enjoy the process. It's a pain in the ass, but it's a fun pain in the ass.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 04-22-2018, 09:01 PM   #3
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
Be sure to secure the steering wheel so it doesn't migrate. And make sure the steering box doesn't drop so the steering column comes out. I've run out of gas a number of times, because I can't see the gas gauge thru my upside down steering wheel.
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
Old 04-22-2018, 10:25 PM   #4
M_Metzger1114
M_Metzger1114 has a spectacular aura aboutM_Metzger1114 has a spectacular aura about
M_Metzger1114's Avatar
1994 SW2
1997 SW2
Also you might checkout the area where your trailing arms bolt to the body. If this area is rusted out, it's probably not worth putting the time and money into a new cradle.
1996 SC2 Manual
1993 SC2 Manual
1997 SW1.5? DOHC with MP2 trans 210k
1998 SW1 Auto
1997 SL1 auto parts car
Add to M_Metzger1114's Reputation
Rate the quality of this post and help M_Metzger1114 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M_Metzger1114 is offline   Reply With Quote
Front end frame rust 2000 SL2 sbr65nj S-Series Tech 12 06-23-2012 10:57 PM
RUST HOLE! in the FRAME of my 94 sl1 trooper94 S-Series General 3 12-02-2011 10:34 AM
Rust around door frame. General advice? CqOUzwsT S-Series General 3 05-03-2011 10:35 AM
2006 Vue seat frame & latch rust al06vue Vue Tech 17 02-22-2009 10:58 PM
Sunroof Frame Rust Prevention/Replacement Filo Miscellaneous Tech 2 12-31-2002 09:23 AM
