Old 04-21-2018, 12:26 PM   #1
raymondjiii
raymondjiii is on a distinguished road
1994 SC2
Default I had to cut brake line at caliper hose...
Can someone tell me what I should use to replace this fitting on the steel line that connects to the caliper hose. I'm thinking double flare with fitting on steel line and then to something like this fitting:
Inverted flare bubble adapter:
https://www.amazon.com/Inverted-Flar...fittings&psc=1
I cannot break the front brake lines to caliper hoses. So much rust and not enough room to cut them.
Thanks for your help.
Add to raymondjiii's Reputation
Rate the quality of this post and help raymondjiii reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raymondjiii is offline   Reply With Quote
Old 04-21-2018, 02:23 PM   #2
Default Re: I had to cut brake line at caliper hose...
Tried heat from a propane torch? This can allow severely corroded fittings to break loose. Penetrating oil allowed to soak in before heating may allow the artificial bonding to break.
Old 04-21-2018, 03:49 PM   #3
raymondjiii
1994 SC2
Yeah, I let PB Blaster soak in and then hit it with Mapp gas. No luck.
I was hoping to do all four wheels but I can leave the front ones if need be. Just not sure what to use for connecting the brakes lines to the new brake hoses since the OEM had a factory fitting on the end of the lines (not a double inverted flare connector.)
Old 04-21-2018, 07:00 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
There are a bunch of fittings in a kit.
The flaring tool is easy to use.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 04-21-2018, 07:14 PM   #5
raymondjiii
1994 SC2
I figured this out
Bubble flare at the brake hose. Doh!
I thought it was something special. I've only done double flares before and I did not have any bubble flare nuts but now I see the difference.
Old 04-22-2018, 02:38 AM   #6
KNGRK9
KNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura about
I had this issue with my brake hoses, I blew one while under emergency braking measures and my calipers were reversed apparently so they had been rubbing on the hoses. Blew the hose and when I went to replace it could not get the hose off. So I ended up chopping up the steel line and completely replacing the front end lines.
1999 SL2 HCE - 245k (wrecked)(rebuilding)
2004 Ion Redline - 108k
Add to KNGRK9's Reputation
Rate the quality of this post and help KNGRK9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KNGRK9 is offline   Reply With Quote
Old 04-22-2018, 06:13 AM   #7
raymondjiii
1994 SC2
I would actually love to replace all 4 lines completely - but I'm not sure where they go - do they come off the booster and if so where do they connect.
If only one could (still?) buy pre-formed lines too. It's not too bad given the clips that the rear lines fit in.
Old 04-22-2018, 08:39 AM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
It would be difficult to get them shipped to NY, but southern salvage yards have S-Series brake lines that look about a month old.
If you have a brake line to use as a template, you can bend yourself a new set. It is not difficult and you could add as many splice joints/fittings as you want to make installation easier.
You coud go to a salvage yard and pay someone to hold the propper S-Series in the air while you remove the brake lines. ...in pieces using side-cutter pliers and such.
Old 04-22-2018, 08:43 AM   #9
Waiex191
Waiex191's Avatar
You could not get a prebent right rear line in without taking apart the car. If you are comfortable plumbing, buy nicopp and bend them yourself. My brake line documentation starts on page 6 of my thread.
http://www.saturnfans.com/forums/sho...=230898&page=6
To bend the nicopp, we just matched it to the old line and taped them together as we went.
It is nice to have all new brake lines!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Does anyone know the name of the brake line/hose bracket? owbowagowy Vue General 5 10-09-2016 05:01 PM
Caliper, Brake Line or Master Cylinder? InVue Vue General 8 05-14-2014 12:02 PM
2005 Vue caliper brake line newbievueowner Vue Tech 3 08-10-2009 07:22 PM
Picture Request: Drivers side Brake Line to Caliper .kevin. S-Series Tech 14 08-02-2009 09:54 PM
Brake hose/line problem Diaconic S-Series Tech 2 07-17-2005 03:13 PM
