Old 04-18-2018, 01:42 AM   #1
Packrat1
Packrat1 is on a distinguished road
2001 SW2
Default Reverse slam?......and other issues
Ok, so for the past few days my sw2 has been acting weird. First, the S.e.s. light comes on, scanner showed a po410 code. Light went off the next day. 700 miles since then and still off. Next the motor mount bolts shook loose. Cleaned the bolt, sadded blue treadlock and reassembled. Today on my way home from work I noticed a somewhat rough engagement of reverse gear. Not sure if this is considered as a symptom of reverse slam or not, but it's appears to shutter in drive too. When it shifts it acts like it's going into neutral for a split second, then goes to the next gear. No ses light currently. Problem is intermittent. Was considering wolfmans cure for reverse slam using "hydra trans tune" Any thoughts? Hope the issue isn't the input shaft nut.
1995 Saturn SW2 5speed (retired @ 350,412 miles)
2001 Saturn SW2 (work in progress)
Add to Packrat1's Reputation
Rate the quality of this post and help Packrat1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packrat1 is offline   Reply With Quote
Old 04-18-2018, 08:04 AM   #2
toggenburg
toggenburg's Avatar
Default Re: Reverse slam?......and other issues
Sure, that cure process solves issues, but I would ask when was the last time the trans fluid was changed and a new spin on filter done?
It should be changed out at least every 30,000 miles, using ONLY Dexron III compatible fluid.
Secondly, what kind of heavy vibration loosens a TAM bolt/nut?
Sounds like you need to look at replacing the transmission TAM and the dogbone mounts also.
Old 04-18-2018, 10:38 AM   #3
Saturn Night
Transmission fluid level should be checked.
A new filter and new fluid should be changed, if the car has been driven more than 30,000-miles or has gone more than 2-3 years since it was last changed.
The alternator output should be tested, to confirm that the electrical supply to the transmission, is at 14.2-14.4v coming from the battery. Anything below about 14.0v will cause shifting issues.
Symptoms of the input shaft nut will be a P0732, reverse slam/no reverse, and slamming gears on upshifting in drive.
Old 04-18-2018, 03:53 PM   #4
Packrat1
2001 SW2
not sure when it was last changed, but is nice and pink. Bought the car about 2 years ago with 110k on the clock. At 130k I changed the filter while looking for a very slow trans leak. Currently sitting at 148k. Guess it's due despite being clean and highway driven. It "hydra trans tune" a good product to use? How much trans fluid for a drain and fill? So far, ive replaced the trans temp sensor and added a filter magnet.
Old 04-18-2018, 04:52 PM   #5
toggenburg
toggenburg's Avatar
Color is subjective, but should be RED, not pink.
Not familiar with that additive, whenever I have done the Wolfmans' reverse cure (on several makes of cars and pickup trucks), I have added Lucas Trans Fix from Walmart ~$11.
First off, I would ditch any magnet, depending on who manufactured the trans filter you are using, it may block those drainage holes in the top of the filter.
Ditch IT and never put one back in, especially since you are having issues.
Old 04-18-2018, 09:27 PM   #6
Packrat1
2001 SW2
I thought Lucas was thick stuff. Like cake batter thick. I know it helped my mother's '01 Toyota Sienna as it started to slip about every 25k miles. Works good for a slipping trans. Filter is a PowerTorque FK243. Magnet was on this side of the filter. How about a magnet on the top of the trans? Probably not much oil being slung up top, but I just feel better knowing there's a magnet grabbing some of the metal out of the oil. Trans shifted normally this morning. Started acting up again couple hours later.
Old 04-21-2018, 12:31 AM   #7
Packrat1
2001 SW2
The slamming got worse last night. It's doing it forward and reverse. Limped it home 120 miles. 1-2, 2-3,3-4 shift all feel like I'm hitting a pothole. Guessing the input shaft nut is loose. Question, what causes it to get loose?
Old 04-21-2018, 07:00 AM   #8
toggenburg
toggenburg's Avatar
Abusing the trans by jackrabbit starts like trying to 'patch out', and not keeping up with necessary trans fluid changes. The reverse slam is a symptom and if ignored long enough over time....
How many miles on it and how long have you owned it?
Old 04-21-2018, 02:00 PM   #9
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Slam on all shifts makes me suspect the LP circuit/solenoid is bad. Check the fuse, then check the coil resistance (both easy to do). If nothing is obviously wrong with those, then use a gauge to check LP and verify if LP "stuck high" is the problem
Add to billr's Reputation
Old 04-21-2018, 02:15 PM   #10
Cheyne
2000 SL2
^^ Check this. If fuse in UHJB is good, the LP solenoid is suspect. Check YouTube for video on how to test resistance.
Add to Cheyne's Reputation
Old 04-29-2018, 01:29 AM   #11
Packrat1
2001 SW2
LP as in line pressure? Which circuit is this fuse in?
Old 04-29-2018, 01:33 AM   #12
Packrat1
2001 SW2
ok. Will look for video.
Old 04-29-2018, 10:35 AM   #13
Saturn Night
The reverse slam causes the input shaft nut to loosen. It also causes you to lose reverse and generates a P0732 code for "Second Gear Incorrect Ratio/No Second Gear".
Old 04-29-2018, 04:00 PM   #14
billr
Yes, "LP" is line pressure. In the gen1 that fuse is labeled "TRS LP", I suspect your year is similar.
Old 08-11-2018, 11:01 PM   #15
Packrat1
2001 SW2
Update: replaced valve body. The slam seems to be gone. Shifts a tad firm, but not harsh. Only drove about a 1/2 mile. Hope there nothing to worry about. Also SES light came on. Shows a code po037. Seems like an odd coincidence to show up now, but will pick up a o2 sensor in the morning.
Old 08-12-2018, 01:27 AM   #16
billr
You will need to drive it a while for the PCM to re-learn the shift parameters. There is a procedure to do this re-learn quickly, but just driving for a while will do it. Just 5-10 miles should be enough, but you will have to be going at varying speeds that require shifting into all the gears several times.
Old 08-15-2018, 06:26 PM   #17
Packrat1
2001 SW2
Ok. Drove about 15 miles today. Seems to be back to normal, but check engine light persists. Replaced downstream o2 sensor and cleared the code, but came back right away. What else would trigger a po037?
Old 08-15-2018, 06:38 PM   #18
toggenburg
toggenburg's Avatar
I have no experience with that heater code, however; back in 2009 while addressing that code on a '98, OldNuc said,(P0037 Heater Circuit Low Voltage)
http://www.saturnfans.com/forums/sho...d.php?t=136349
"You can try disconnecting and reconnecting the plug. Its located on the rear cross tube of the cradle, right behind the steering rack. There is a connector lock pin in it that has to come out before it will unplug."
2002 sc2 reverse slam and overdrive slam scw2 S-Series Tech 3 09-01-2016 08:09 PM
Reverse slam and slam in all gears after replacing bad solenoids OldManTain S-Series General 4 07-14-2014 09:50 PM
reverse slam, slam into 2nd, p0732, now no reverse...new valve body? nd99sl2 S-Series Tech 12 09-28-2010 10:07 PM
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 06:48 PM
Reverse Slam and 2nd gear issues from nowhere. EvilSL2 S-Series Tech 12 01-05-2008 09:45 AM
