Old 04-16-2018, 10:32 AM   #1
coolengineer
coolengineer is on a distinguished road
1999 SC1
Default What would damage a power steering pump
Hi everyone, yesterday I got my 99 sc1 stuck in the snow several times, due to the inclement weather that northern michigan has been getting lately, and I noticed that my power steering pump was making loud noises when I was turning tight corners while moving slowly. The pump was not making any noises as far as I was aware before yesterday. So was just wondering what would cause a power steering pump to go bad.
coolengineer is offline   Reply With Quote
Old 04-16-2018, 10:52 AM   #2
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Default Re: What would damage a power steering pump
Check to see that there is not something jammed in suspension that the
pump is fighting against. The pumps are hard to kill, so hopefully it is something obvious.
Is the fluid level ok?
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
SLfun is offline   Reply With Quote
Old 04-16-2018, 11:03 AM   #3
coolengineer
1999 SC1
It turned extremely easily when I did some donuts in my college parking lot. It only made noises below 10 mph while turning hard over in either direction. But, I will definitely check for obstructions and I will check the fluid as well. But, I mean I spent a little more than an hour revving my engine to get the car to rock back and forth. I don't know if I can damage anything on the engine doing that.
Old 04-16-2018, 11:38 AM   #4
SRGW
1997 SL1
Post Re: What would damage a power steering pump
Check to see if the pulley is cracked or broken around the center, as it is made out of plastic. Had this happen on my 1995 SL1.
1995 SL1 235,000 Well Oiled!!
1997 SL1 63,890 Just A Teenager!!
CHECK YOUR OIL!!
Old 04-16-2018, 12:52 PM   #5
Saturn Night
If the pump is whining and noisey, either the pump shaft bearings are starting to fail or the fluid level is low.
This is a sealed system, so the fluid can deteriorate and get low, unexpectedly, but this is very rare.
It is more common for a slow leak to cause a low fluid level.
Old 04-16-2018, 01:44 PM   #6
Macgyver
Are you still running the same power steering fluid from 20 years ago? If so, flushing it out with new fluid would be a good start.
Power steering pump? 64waves L-Series Tech 9 12-03-2015 03:23 PM
Power steering pump small leak - slow death, or change pump now? Upstate Saturn S-Series Tech 19 11-20-2014 05:08 PM
Photo of new power steering pump leaking from hole in casting. Bad pump? tgferg67global S-Series Tech 1 11-10-2010 06:11 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
L Power Steering Pump spork Miscellaneous Tech 12 01-07-2002 04:02 PM
