Old 04-15-2018, 11:52 PM   #1
Youbettermakeup
Youbettermakeup is on a distinguished road
Default 05 Vue won't start, no check engine light after hitting deer
Hi y'all
It all started after my husband hit a deer, destroying the cooling fan and radiator, as well as the a/c condenser. He drove it to work while stopping to refill the coolant tank and so it wouldn't overheat. Later that day he drove it home stopping along the way to let it cool down and kept refilling it with water. When he got outside of town he stopped to let it cool down and it stopped being able to start. He replaced the radiator and now its rolling over but won't start. The fuel pressure gauge jumped to 58psi then a second later dropped to below 50psi holding at about 46psi. He checked the fuses and they were fine. There's no check engine light.
Any help would be appreciated.
Add to Youbettermakeup's Reputation
Rate the quality of this post and help Youbettermakeup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Youbettermakeup is offline   Reply With Quote
Old 04-16-2018, 02:02 AM   #2
pierrot
pierrot's Avatar
Default Re: 05 Vue won't start, no check engine light after hitting deer
Welcome to SaturnFans, Youbettermakeup! It will help everyone to know which engine is in your VUE.
You can make this easier on yourself if you return to the User CP>go to Edit Your Details>scroll down to Primary Saturn Model Year and Primary Saturn Model Type and fill in that information. It will appear beneath your login name each time you post a message and be there for all to refer to. It helps to reduce unnecessary questions and possible confusion.
1) What does the oil look like? Does it appear normal on the dipstick?
From NAPA: "Coolant-contaminated oil takes on a frothy consistency; itís like finding a latte under your oil cap or in the valve covers." Refer to the link below.
http://knowhow.napaonline.com/eight-...n-head-gasket/
2) Presence of spark needs to be verified. If that is good then,
3) a compression test should come next.
4) Was there any wiring damaged in this accident?
300,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 04-16-2018, 02:43 AM   #3
Youbettermakeup
1. The oil looks normal.
2. There is spark!
3. How would a compression test be done? We can't afford to have a mechanic do one right now
4. It looks like there might be some but my husband is going to look into that tomorrow.
And I edited my profile to reflect that!
Old 04-16-2018, 03:31 AM   #4
Check for fuel on spark plugs - several starting attempts should have very wet plugs to indicate injector operation. No wet, fuel smelling spark plugs would suggest zero injector operation. One fuse powers injectors. If plugs are soaked in fuel, the engine may have flooded. Dry off wet plugs, crank the engine a few seconds without plugs to blow out excess fuel, replace plugs and try starting again.
Old 04-16-2018, 07:34 PM   #5
atikovi
1) Conceivable that filling it with cold water could crack the head or block.
2) Some cars you have to bleed the system when adding water or else there is air in the system and temperature won't register properly. Could have blown the head gasket.
Add to atikovi's Reputation
Old 04-16-2018, 08:22 PM   #6
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
I did almost this exact same thing with my old VW Fox when it got a pinhole leak in one of the radiator hoses. Blew the head. You could tell from the oil that coolant had gotten into it though.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
Old 04-16-2018, 10:03 PM   #7
pierrot
pierrot's Avatar
Good!
2. There is spark!
Good!
3. How would a compression test be done? We can't afford to have a mechanic do one right now.
Follow fdryer's suggestions first. If it starts and runs normally then you can dismiss the compression test for the time being. Should the test be necessary, however, you will need to borrow a compression gauge from one of the national chain auto parts stores which have a tool loan program - O'Reilly's, Autozone, or Advance. Follow instructions which should be included with the tool regarding its use. It's not difficult but may require a second person to assist if a remote starting switch is not being used.
Great! Thank you.
Key intermittently won't start, traction light came on, check engine light comes on ianspb Aura General 6 08-16-2016 04:07 AM
Failed Smog Check After Erasing Check Engine Light Code trench619 Ion General 9 05-01-2015 11:58 AM
Error codes after hitting deer almies Vue Tech 13 01-16-2015 11:23 AM
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 05:38 PM
Anybody wanna know how a Outlook holds up after hitting three deer at 40mph? Click-it Outlook General 10 10-03-2009 09:05 PM
