Old 04-15-2018, 10:20 PM   #1
RobertGary1
Default Hot front brakes
For years people on this forum have speculated that an internal binding happens in the front brake flex line that causes our overheating symptoms (warped rotors, hot spots, premature pad wear). I had those symptoms for years. Earlier last year I suction bled both front brakes. Since then my pads still have lots left in them, no hot spots, and no pulsing. Normally this time of year I'd already be replacing the brakes.
So its just one data point but I suspect the cure has more to do with flushing the fluid after changing the lines that actually changing the lines. At least its an inexpensive solution you may want to try.
-Robert
RobertGary1 is online now   Reply With Quote
Old 04-16-2018, 09:56 AM   #2
Rivernut
Rivernut will become famous soon enough
Rivernut's Avatar
Default Re: Hot front brakes
I believe I had the original post here about this as it happened on more than once on our 2003 Vue. I believe it is just a front disc brake issue. The cause was actually not the hose itself but the bracket holding the hose. The bracket fits around the hose and is very rust prone. The expansion of the rust exerts pressure on the rubber line, much like a boa constrictor suffocating its prey. The tell-tale signs are dragging front brake(s), hot brakes and rim, and pressure relief only by cracking the bleeder. It is a good idea when doing a brake job to open the bleeder and purge the lower (usually contaminated) fluid out as the caliper piston is compressed into its bore. If the fluid is pushed back up the line it may gunk-up the ABS module which can lead to more expensive repairs. Brake fluid is supposed to be replaced every couple of years anyway as it absorbs moisture and gets soupy with rust. So itís a good idea to draw fluid out periodically, but It wonít prevent the external constriction of the line from the bracket corroding.
Add to Rivernut's Reputation
Rate the quality of this post and help Rivernut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rivernut is offline   Reply With Quote
Old 04-16-2018, 10:01 AM   #3
Chazberry
Chazberry's Avatar
No speculation Robert. It's a proven fact that the hoses are to blame. Those hose support clamps were over-crimped at the factory . . .
http://www.saturnfans.com/forums/att...6&d=1405617590
Add to Chazberry's Reputation
Old 04-16-2018, 10:16 AM   #4
mlc5
mlc5 is a jewel in the roughmlc5 is a jewel in the roughmlc5 is a jewel in the rough
I think it's safe to say that if both sides of the brakes are experiencing the same problem.. then it's unlikely that both hoses would fail at exactly the same time... and then it more likely to be related to fluid issues/master cyclinder, etc.
Add to mlc5's Reputation
Rate the quality of this post and help mlc5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlc5 is offline   Reply With Quote
Old 04-16-2018, 12:09 PM   #5
RobertGary1
Why would that not manifest itself immediately?
The reason I decided to try the flush was because it did seem odd that both sides would start having the same issue.
Last year I bled the brakes on my aircraft and found it also made a huge difference. I just wish bleeding was as easy as it is on cars. But I suspect that is because aircraft hydraulic fluid gets gooy over time. DOT 3 doesn't seem to do that.
-Robert
Old 04-16-2018, 01:36 PM   #6
Chazberry
Chazberry's Avatar
Did you look at my photo? It's pretty obvious that clamp was squeezing the line closed. Apparently they weren't completely squeezed shut from the git-go. Maybe the rubber swells over time until it closes the line the rest of the way(?). Both my '03 and '07 didn't experience dragging brakes until they had over 100k miles.
Old 04-16-2018, 01:38 PM   #7
RobertGary1
That's why I asked the question. The picture seems to indicate a condition that would have existed from the initial install.
-Robert
Right front brakes 04 Vue awd v6 Janak42 Vue General 3 10-08-2017 11:54 AM
LW-300 Front Brakes JTav8r L-Series Tech 5 02-13-2017 11:54 PM
Front Brakes vs Rear Brakes? Saturn S-series EvanVanVan S-Series Tech 25 11-14-2011 08:39 PM
Front brakes yazhere S-Series Tech 6 12-15-2006 02:49 PM
New Front Brakes andyr13 S-Series Tech 6 07-18-2005 09:07 PM
