Old 04-08-2018, 05:47 PM   #1
patrickstapler
patrickstapler is on a distinguished road
2008 VUE 3.6L
Default Head Gasket???
Hoping for not. My wife's '08 3.6L Vue got hot last Thursday. Immediately pulled over and shut off. Check water light came on...so I did. It was a gallon low. No apparent leaks anywhere. Couldn't even smell coolant. No water in oil. No smoke out the tail pipes. Engine runs normal. No CEL. No codes. 120,000 miles.
Had to go out of town and just returned today. Removed engine cover and noticed pool of coolant on top of the engine and in a small valley just below the what I assume to be the thermostat housing of the driver side of the engine.
Any help would greatly appreciated.
Thanks,
Patrick
Add to patrickstapler's Reputation
Rate the quality of this post and help patrickstapler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patrickstapler is offline   Reply With Quote
Old 08-04-2018, 09:14 PM   #2
Doug C
Doug C's Avatar
2008 Outlook XE
Idea Re: Head Gasket???
Patrick;
you may not have got any response 'cause you posted in the most likely forum.... try this one to move everything over here;
http://www.saturnfans.com/forums/forumdisplay.php?f=20 aka Vue s !
IMHO
nite.
Add to Doug C's Reputation
Rate the quality of this post and help Doug C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
#2 Cyclinder plug Gunked up continually, cracked head or leaky head gasket? kewlpop S-Series Tech 13 02-14-2018 05:05 AM
Is it possible to repair a oil leak from the head gasket without replacing gasket? tgferg67global S-Series Tech 13 12-23-2010 08:39 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 10:08 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 04:26 AM
