Old 03-22-2018, 10:34 PM   #1
NWSaturn247
NWSaturn247 will become famous soon enough
NWSaturn247's Avatar
1993 SL2
Default Installing a new exterior door handle gen2
Anyone with a link to an instructional?
Thank you.
1993 SL2 AT - 186k miles
running blend of various SOPUS oils & D3422
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 03-22-2018, 10:41 PM   #2
Default Re: Installing a new exterior door handle gen2
2nd step here: http://www.differentracing.com/tech_...doorpanel.html
Old 03-23-2018, 08:23 AM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by fetchitfido View Post
In the picture, what is that grey thing shoved in under the green thing? Asking for an acquaintance.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 03-23-2018, 08:56 AM   #4
Saturn Special Tool, part # 228987a68hk,
List price $589, available at your local Saturn dealership
I think it is the most weirdly drawn screwdriver ever.
Old 03-23-2018, 09:12 AM   #5
I don't even know what it's for let alone what it is. Replaced a few door panels on 1st and 2nd gens without knowing it existed...lol
Old 03-23-2018, 09:15 AM   #6
^ ^ ^ Yeah - I used that same link for reference and never noticed that weird grey shape. I just used a screwdriver or whatever was handy to hold the door handle up, while I dug those pins out.
Old 03-23-2018, 12:26 PM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
What you are seeing is an out-of-control CAD Drafter in Troy, Michigan.
Project Manager, Just draw in a screwdriver or something. Im going to lunch.
Drafter, I got this.
Old 03-23-2018, 01:05 PM   #8
floridasl22002
floridasl22002 is a name known to allfloridasl22002 is a name known to allfloridasl22002 is a name known to allfloridasl22002 is a name known to allfloridasl22002 is a name known to allfloridasl22002 is a name known to all
Are you just wanting to replace the exterior door pull. The plastic molding you grip with your handle and pull up to open the door?
If you are, nothing could be more simple.
Simply lift the handle and wedge a screwdriver under it to stop it dropping down. Then you pop out the plastic retainer that holds the handle to the mechanism. Once the plastic retainer is popped out, remove the screwdriver and just the handle off. Simple as that.
Refitting is a reversal of same.
There is a video by Richpin on removing the outer door skin. In that video he removes the door handle in the way I just described
Exterior door handle mateas S-Series Tech 3 11-04-2016 04:31 PM
Gen2 Door Panels In Gen1? dragonslord S-Series General 3 09-10-2012 06:57 PM
Help getting the exterior door handle off! number9 S-Series General 5 01-01-2006 06:44 PM
Repair exterior door handle 85_SS S-Series General 1 12-19-2005 01:00 PM
Loose exterior door handle Mike_SW2K Miscellaneous Tech 1 02-16-2004 09:43 PM
