Old 03-22-2018, 04:19 PM   #1
Tripp
Tripp is on a distinguished road
Default Saturn wont idle
1998 Saturn SL2, have replaced every part under the sun, has been running fine, suddenly it wont run unless I have it reved up, at idle it just chokes and cuts off. Started last night.
Have replaced catalytic convertor, TPS, fuel filter, among a ton of other stuff. Only thing I have not ever touched is the fuel pump.
20 years old, 235,000 miles
Add to Tripp's Reputation
Rate the quality of this post and help Tripp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tripp is offline   Reply With Quote
Old 03-22-2018, 08:54 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Saturn wont idle
IAC (idle air control) value needs replacing.
Old 03-22-2018, 09:16 PM   #3
1998 Saturn SL2, 235,000 miles and you expect they pump to last forever? When in doubt, test. Borrow a fuel pressure gauge from AutoZone or Advance Auto. You might have to leave it connected to observe if pressure drops of dramatically when the whole p engine won't idle. Guessing is easy. Eliminating possible issues requires testing to remove all doubt.
Testing the idle air control valve is simple and described many times. The easiest test is to block off the port in the throttle body throat in front of the throttle plate with a normal (650-850 rpm) idle. The idle should drop to 500-600 rpm. Unblock the port and idle should jump up immediately then return to normal idle. The jump and return to normal idle is the PCM commanding the iacv to fully retract then extend to maintain idle rpm. You're blocking the supplemental bypass air port the PCM needs to control idle speeds. The iacv is metering airflow for electronically controlled idle rpm. If this doesn't occur, something's wrong.
Old 03-23-2018, 06:45 AM   #4
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Have you bothered to do a true cleaning of the throttle body and IAC valve and ports? If not do it. Odds are that is your issue.
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
wont relearn idle chaosVue Vue Tech 6 12-05-2015 06:43 PM
2005 Saturn Vue turns over, but wont start + IC wont work BlueVueMN Vue Tech 2 06-10-2015 04:50 PM
95 Sl2 wont idle jbanderson L-Series Tech 2 07-06-2011 05:00 AM
Car wont idle sustek S-Series Tech 7 10-11-2009 10:48 AM
My sl1 wont idle ProudAudiOwner S-Series Tech 19 07-27-2007 03:17 PM
