Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 03-22-2018, 03:05 PM   #1
doodles
doodles is on a distinguished road
Default saturn transmission
Will a 2001 Saturn L100 transmission fit in a 2001 L200 transmission
Add to doodles's Reputation
Rate the quality of this post and help doodles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
doodles is offline   Reply With Quote
Old 03-23-2018, 02:17 AM   #2
pierrot
pierrot's Avatar
Default Re: saturn transmission
Welcome to SaturnFans, doodles! Your question is oddly worded. As written, you're asking if one transmission will fit into another one. I don't believe that's what you intended to ask, so I will reword your question:
will the transmission from a 2001 Saturn L100 replace the transmission from an L200 of the same model year? In a word, yes.
There was only one automatic and one manual transmission for all L-Series cars with the four cylinder engine, although according to the GM cataloging there are different part numbers for the '03 and '04 automatic transmissions. Manual transmissions were supposedly discontinued in after '03.
So what is it that you are considering for one of the L-Series cars you've referred to?
298,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 03-23-2018, 04:03 PM   #3
doodles
well i have a saturn l200 with a automatic transmission it kinda shifts bad some times not like mostly in reverse it has 200000k miles with the stock parts so i wanted to know if the L100 has inter change able parts so i can save a few hundred buck.
Old 03-24-2018, 01:37 AM   #4
pierrot
pierrot's Avatar
I'm all for saving money on repairs so I'm with you.
Questions:
1) Does this "bad" shifting occur with a certain regularity, or predictability?
2) Does it happen intermittently so that you don't know when it will happen again?
3) What do you feel, or hear - if anything - when the bad shifting takes place?
4) What is the maintenance history for your L200's transmission?
(The transmission on my car hasn't had any internal hardware replaced. The only work done has been the required fluid changes.)
Old 03-24-2018, 04:11 PM   #5
doodles
it happen intermittently and kinda a clunk sound and i dont think in it has been fluid changed
Will a Saturn SL Transmission fit a Saturn S Series?? SnoCapFairy S-Series Tech 10 08-10-2017 01:10 PM
2004 vti saturn transmission awd be swapped with a transmission in a 2005 fasttrack Vue Tech 1 12-16-2016 04:47 PM
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 09:28 AM
Saturn sl2 - transmission omasterkelly S-Series Tech 5 07-01-2015 02:40 PM
Saturn Ion How To Tell What Transmission I have M43 or M75 (CVT) Spawn Ion General 5 04-14-2014 02:17 AM
