Old 03-20-2018, 06:44 PM   #1
jemstudio
jemstudio is on a distinguished road
2007 VUE 2.2L
Default ticking sound at start up
I get a ticking sound on startup 2007 vue 2.2 l 4 cyl but it only lasts a moment then goes away? sounds like a spark sound or a lifter sound not really sure but like I said it goes away fast or should I say the sound gets lower after a minute or so.
Add to jemstudio's Reputation
Rate the quality of this post and help jemstudio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jemstudio is offline   Reply With Quote
Old 03-21-2018, 07:59 PM   #2
RGRG68
RGRG68 is on a distinguished road
2004 VUE 2.2L
Default Re: ticking sound at start up
Does the ticking ever go away completely? Usually lifters just get quieter, But sometimes they do seem to disappear as the engine warms up.. A spark plug wire will tick the entire time.
Add to RGRG68's Reputation
Rate the quality of this post and help RGRG68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RGRG68 is offline   Reply With Quote
Old 03-21-2018, 09:33 PM   #3
jemstudio
2007 VUE 2.2L
it goes away within a minute or 2 on cold start then I don't hear it anymore.
Old 03-22-2018, 07:40 AM   #4
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
2004 VUE 2.2L
Mine (2004) did the same thing - took longer to go away in the cold weather than in the summer. Turned out to be the exhaust manifold - one of the bolts broke. Once the manifold was replaced and bolt repaired, noise gone.
I drove it for about 7 years that way. I wouldn't have ever fixed it but it finally caused a check engine light cause the O2 sensor would get confused because of the leak.
Add to john95SW2's Reputation
Rate the quality of this post and help john95SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john95SW2 is offline   Reply With Quote
Old 04-02-2018, 02:39 AM   #5
jemstudio
2007 VUE 2.2L
seems to be getting louder and lasting a little longer ... the sound is driving me nuts
Old 04-04-2018, 07:40 AM   #6
99WhiteC5Coupe
99WhiteC5Coupe will become famous soon enough99WhiteC5Coupe will become famous soon enough
Do you have the correct OEM oil filter and correct viscosity oil installed on the engine? Is the engine oil level correct?
A poor-quality aftermarket oil filter (or one that is partially clogged) can cause oil starvation at engine start-up, and the ticking noise. Incorrect oil viscosity can also cause engine ticking at start-up. A low engine oil level can also cause ticking at start-up.
Add to 99WhiteC5Coupe's Reputation
Rate the quality of this post and help 99WhiteC5Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99WhiteC5Coupe is offline   Reply With Quote
Old 04-04-2018, 08:09 AM   #7
thegreatbriguy
thegreatbriguy has a spectacular aura aboutthegreatbriguy has a spectacular aura aboutthegreatbriguy has a spectacular aura about
2004 VUE 2.2L
Are you sure its not the timing chain? it can sound a little diesely or like a tick when the tensioner is first going bad. its on the passenger side of the engine.
Add to thegreatbriguy's Reputation
Rate the quality of this post and help thegreatbriguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thegreatbriguy is offline   Reply With Quote
Old 04-04-2018, 07:29 PM   #8
jemstudio
2007 VUE 2.2L
everything up to par... can't
figure it out
Old 04-04-2018, 07:30 PM   #9
jemstudio
2007 VUE 2.2L
gotta check that out ty
ticking sound? WS1993 S-Series Tech 8 10-01-2015 08:14 PM
Bad ticking sound Mozz Ion General 18 01-06-2015 05:54 AM
ticking sound billbat L-Series General 8 01-15-2009 12:51 PM
Ticking sound Wired220 S-Series General 8 06-12-2004 10:58 PM
Ran with low oil..now a ticking sound? TIMSPEED Miscellaneous Tech 5 08-09-2002 09:26 PM
