Old 03-20-2018, 06:58 PM   #1
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default Random issues today
I don't know if it is coincidence or not but weather was crappy (snow, sleet, rain) and my car was acting up driving home from work today. First, it wouldn't start. Took me 4-5 attempts. once i got it started, and drove in traffic for 5 minutes, the idle would jump way up to 3k rpm and hold there and then drop back down and this continued for my entire drive and at random which was a pain in the ass. when I had to put it in first or second and let the clutch out, it would accelerate a bit too much and then i was hitting my brakes and constantly putting it in neutral while watching the revs stick and hold at 3k for upwards of 30 seconds at times.
Another random issue I saw, which is probably unrelated, was my temperature gauge kept dropping to below Cold like it was losing the signal. Then it would jump back up to normal, then back down, sometimes jump back up half way, then back down. very random.. probably need to look for corrosion on the wire to the ects sensor
check engine light has been on for the egr valve but haven't checked lately to see if there are any other codes.
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 03-20-2018, 09:58 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Random issues today
Check for vacuum leak, like a hose off, or spray brake cleaner nearby the valve cover gasket area and see if idle spikes or not.
Old 03-20-2018, 10:40 PM   #3
Cheyne
2000 SL2
Check the connector and read the codes. You may have more than the EGR code now, and it may help to confirm the problem.
As mentioned by toggenburg, you will want to check for a vacuum leak at the intake manifold. The 3rd gen SOHC had problems with the intake manifold gasket. I believe it was usually around cylinder 1 and would often throw a misfire code.
You might also want to clean the throttle body, paying particular attention to the IAC.
Add to Cheyne's Reputation
Old 03-20-2018, 11:21 PM   #4
Saturn Night
Use the scanner to check TPS % in Live Data as well. Plan on buying an intake gasket kit, as every single last 3rd Gen SOHC seems to have problems with the gasket shrinking, which will cause a P0301 misfire code.
Old 03-21-2018, 12:34 PM   #5
bluesl2
bluesl2's Avatar
Check the coolant sensor before anything else, as it has a huge effect on the air/fuel mixture. Make sure there is no corrosion in the connector.
Add to bluesl2's Reputation
Old 05-20-2018, 10:15 PM   #6
rgrafton
rgrafton's Avatar
2002 SC1
Finally getting around to working on it tomorrow! It's been sitting as I haven't had time to get to it.
I went ahead and purchased the intake manifold gasket because I'm pretty sure that is the problem here.... but I will spray some carb cleaner around there first to confirm
Old 05-21-2018, 08:07 AM   #7
2NDSOUT
2NDSOUT's Avatar
1999 SL
Last time, a few years ago, when I had a high idle- it was the Throttle Body sticking. Before replacing the intake manifold gasket, why not try cleaning the Throttle body first? Carbon buildup on the butterfly valve can change how the car idles- with RPMs jumping up and sticking at 3K RPMs or higher.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
99 sc2 random fuel pump issues Davecarrr414 S-Series Tech 15 07-18-2016 06:49 PM
ECM issues? Random codes, P2138, P833, O2... 07saturnion Ion General 6 06-03-2015 10:14 PM
Couple random issues for my sl2 randysl2 S-Series Tech 2 01-21-2014 10:34 PM
Random reverse bang today taatman S-Series General 6 11-03-2012 12:27 AM
Need Help: Random MissFire P0300 and other issues Motorhead62 L-Series Tech 4 12-31-2007 06:24 PM
