Old 03-19-2018, 07:50 AM   #1
JakeJ
JakeJ is on a distinguished road
Default Saturn Ion Wheel Swap
Just joined the forum. Done some research online and on this forum and looking for a direct answer to my questions. Thank you for any help.
We currently have a 01 Saturn SL2 with the factory 15 inch wheels with new tires on it, we are looking at purchasing a 2006 Saturn Ion with factory 15 inch wheels.
I'm reading conflicting advice on whether the center bore is the same between the two vehicles wheels. Are they both 57.1 center bore?
They also have a different positive offset from what I've found. With 42mm offset on the Ion and 50mm offset on the SL2.
Would I be able to swap wheels between these two vehicles without any issues? (I know the tires are about 1/2 inch different in total diameter, so the speedometer will be slightly off) 195/60r15 on ion vs 185/60r15 I believe on SL2.
Add to JakeJ's Reputation
Rate the quality of this post and help JakeJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JakeJ is offline   Reply With Quote
Old 03-19-2018, 09:43 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Saturn Ion Wheel Swap
The wheels from your SL2 should fit just fine. I once temporarily mounted the 15 alloy wheels from a 2000 SC2 on my Ion and had no fitment issues.
2007 Ion 2 Quad Coupe 5-speed manual 178K miles
2007 Chevy Equinox LT 187K miles
Add to ruley73's Reputation
Old 05-14-2018, 09:08 PM   #3
TGP Z-34 STe
TGP Z-34 STe is on a distinguished road
2005 ION-2 Sedan
Yeah, Ion wheel will not fit on SL2. Older Saturn's center hubcap is bigger in diameter.
I have tried this.
Add to TGP Z-34 STe's Reputation
Rate the quality of this post and help TGP Z-34 STe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TGP Z-34 STe is offline   Reply With Quote
Wheel Swap mnealeigh2 Aura General 2 10-23-2014 12:56 PM
Wheel swap SiflOlly Astra General 2 02-26-2014 05:33 PM
Wheel hub swap Chisel86 S-Series Tech 5 03-18-2009 10:52 AM
Wheel swap? richpor S-Series Tech 4 01-17-2007 02:15 PM
Wheel swap? THX712517 Mods and Performance 5 06-17-2003 09:49 PM
