Old 03-18-2018, 04:13 PM   #1
kg6mvb
kg6mvb has a spectacular aura aboutkg6mvb has a spectacular aura about
kg6mvb's Avatar
2003 ION-1 Sedan
Default Radiator Cooling Fan Problem
The radiator fan in my 2003 Ion with 180K doesn't come on, even with the A/C running. It is warm enough here for AC, and the compressor does kick in. I checked the cooling fan fuse which is fine and swapped the relay with another one. At that point I assumed the fan was bad, so I replaced it.
The new fan also does not come on. If I jumper the switched relay pins (as a test), it comes on. This tells me the wiring, fuse, and new fan are fine. I switched the relay again with one that works in another circuit and nothing.
As a last resort, I "rebooted" the car (removed battery cable for a few minutes). Still no fan.
Any ideas? If needed, I can setup a "ghetto" switch to turn on the fan, but I would prefer to fix it correctly.
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline   Reply With Quote
Old 03-18-2018, 04:46 PM   #2
Default Re: Radiator Cooling Fan Problem
Maybe this wiring diagram can help since you manually bypassed the relay to power the fan. The other side of circuitry is the command side where the ecm commands the fan relay on to power the fan.
Radiator cooling fan has me stumped... cpy911 S-Series Tech 8 09-27-2016 08:28 PM
Radiator Cooling Fan JBravo Vue Tech 8 07-10-2014 07:21 PM
94 SL2 radiator cooling fan not running. amorgan93 S-Series Tech 2 07-24-2010 05:56 AM
radiator cooling fan scalemechanic S-Series General 21 03-31-2010 08:35 PM
Radiator Cooling Fan Glasact L-Series Tech 4 06-04-2007 01:23 PM
