Old 03-17-2018, 11:39 PM   #1
250nm
250nm is just really nice250nm is just really nice250nm is just really nice250nm is just really nice250nm is just really nice
Default Instrument Cluster Lighting
I just had the last backlight bulbs in my instrument cluster burn out on me, and I was wondering what the correct replacement bulbs are. I tried swapping in sylvania PC74s as mentioned in other threads, but I still don't get any backlighting. The bulbs I got are intact and actually work for the warning light spots, just not anywhere else.
I also saw that people are recommending 161s, but they're rated for the same voltage as the others and I'm a bit wary.
"Captain Understeer" - 1999 SL2 with MP2 transmission. My first car!
Add to 250nm's Reputation
Rate the quality of this post and help 250nm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
250nm is offline   Reply With Quote
Old 03-18-2018, 11:20 AM   #2
Default Re: Instrument Cluster Lighting
Check your owner's manual for bulb numbers otherwise try GMs site; http://www.gm.com/owner-assistance/saturn.html. Tried the dimmer knob to see if lighting changes? Whether PC74 or PC161, lamps are sized along with brightness. Incandescent lamps are rated for around 15-16 volts to last most car lifetimes.
Old 03-19-2018, 12:16 AM   #3
250nm
Thank you very much for your reply! I went to a junkyard today and picked about 10 different bulbs (part 161 with the red bases). I checked all of their filaments and saw that they were still intact. After installing them, I got a whole lot of nothing! I even tried all of the dimmer settings, so I'm beginning to think there's something either wrong with the cluster or the wiring to the cluster.
I'll try a new cluster in the next week or so if I can manage.
Is there a fuse for the backlights? Everything but the backlights (say, left and right turn signals, etc.) works, so it's probably not a problem with the 10A fuse in the top left or the ground.
Old 03-19-2018, 08:35 AM   #4
The problem can be either power or ground. Choose one and chase it.
Old 03-20-2018, 12:54 PM   #5
The gauges are not backlit like the warning/signals are - they are lit from the front, mostly by the two "theater" bulbs located at the top, forward section of the panel.
See the pic in this thread
http://www.saturnfans.com/forums/sho...d.php?t=154888
Old 03-24-2018, 10:33 PM   #6
250nm
After looking through my Chilton manual, the 10A "Park" fuse under the hood drives not only tail lights and the tail light warning beeper, but also the instrument cluster front lighting. I checked and the fuse was blown; after replacing it, I now have lights!
Old 03-25-2018, 11:08 AM   #7
J.W.
J.W. is on a distinguished road
2001 SL2
[QUOTE=. I checked and the fuse was blown; after replacing it, I now have lights![/QUOTE]
Two comments come to mind here: " If all else fails.....RTFM "
And: "Too soon Old....too late smart .."
Congratulations ! You fixed it !
(and you learned "next time check the fuses first"
(Usually the easiest thing to do")
Nice job !
Cheers !
Add to J.W.'s Reputation
Rate the quality of this post and help J.W. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J.W. is offline   Reply With Quote
Help with instrument cluster lighting . itsonlysir S-Series General 14 08-23-2011 07:00 AM
'03 instrument lighting GReeder Vue General 22 10-21-2010 01:49 PM
Instrument panel lighting mbhsl200 S-Series Tech 43 03-20-2010 05:14 AM
Instrument panel lighting clintlight27 S-Series Tech 0 12-10-2006 10:47 AM
Flickering Instrument Panel Lighting hugh L-Series General 15 11-25-2003 01:23 PM
