Old 03-16-2018, 09:55 PM   #1
jstutz101
jstutz101 has a spectacular aura aboutjstutz101 has a spectacular aura aboutjstutz101 has a spectacular aura about
Default High Idle after running out of gas..
So my kid ran her 2002 Saturn SL1 out of gas this morning. (Dumb Story) Anyway, I added a few gallons and she started right up. Problem now is it's idling around 3000 rpm. Car was running fine before running dry. The idle doesn't change with engine temp or a/c operation. Any idea's what the connection would be to running out of gas? For kicks I disconnected the battery for the night hoping it corrects itself in the morning.
Thanks for any ideas!
Jeff
Add to jstutz101's Reputation
Rate the quality of this post and help jstutz101 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jstutz101 is offline   Reply With Quote
Old 03-16-2018, 10:59 PM   #2
Default Re: High Idle after running out of gas..
Running out of gas is just one of those learning curves and should not have caused the high idle problem. Coincidence. At 3k rpm, check for a large vacuum leak; brake vacuum hose, pcv valve hose, loosened throttle body, egr valve loosened, anything to allow a large vacuum leak. Examine throttle linkage. Is it stuck open? The throttle stop should show throttle in closed, home position.
Old 03-17-2018, 05:47 AM   #3
jstutz101
I agree, I had her put the pedal to the floor and try starting it before I knew it was out of gas. I wonder if the throttle body is dirty and the plate isn't closing all the way. Naturally we have a full day of high school kid stuff going on today so I won't get to fool with it till tomorrow.
We did learn through the whole fiasco that the gas gauge doesn't go all the way to "E" before running out of gas nor does the "Low Fuel Light" come on.
Thanks for the ideas!
Old 03-17-2018, 01:42 PM   #4
jstutz101
Good News!! I hooked the battery back up and now she's running fine. Lessons learned here for sure!!
Old 03-17-2018, 03:26 PM   #5
Battery disconnect/reconnect to reset an errant high idle? Much better than running around looking for a vacuum leak.
Running very rich and erratic high idle BugsyQ S-Series Tech 20 05-18-2014 01:24 AM
high idle and running rough skullareli S-Series Tech 8 03-04-2010 08:11 PM
High idle + low temp + crappy running car? jarl S-Series Tech 11 03-28-2009 03:27 PM
High Idle and rough running quasar S-Series General 5 12-14-2007 02:48 AM
High Idle, Rough Running, SES 26 &32 - 93 SL1 GmG S-Series Tech 20 05-24-2004 11:11 PM
