Old 03-16-2018, 04:29 PM   #1
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
Default My wipers don't work! Please help!
So hi! I haven't been on here in a while...
Cinnamon, my 1997 SL1 and I are having a disagreement. Her wipers decided not to work. They gradually failed over several months. They were working fine, and then would randomly start going on their own, and then would start doing all kinds of random extra wipes whenever she felt like it. And then... NOTHING.
So I had something similar happen on another Saturn I used to own, so I figured... wiper motor! Went to the pick and pull; got one for $20, swapped it out.
So here is where we are at. I tested it without putting the wiper arms back on and I could see the little nubbins (I KNOW that is not the technical term, but that's what they look like so...) moving back and forth so I think I'm golden!
And now with the dash cover pulled off I can hear the motor running, which I could NOT hear before. So when I pull the switch I can hear the motor coming on... but after putting the wiper arms back on; they don't move.
Is this as simple as me not putting the arms back on correctly, or could it be something else?
Thanks in advance!
Past:
1995 SW2 - Cynthia - sold
2000 SW2 - Ruby - sold
2004 Vue - Jade - traded in
1996 SL2 - Ursula - sold
1994 SL2 - Nelly Belle - sold
Current:
1997 SL1 - Cinnamon - 280K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 03-16-2018, 05:23 PM   #2
bluesl2
bluesl2's Avatar
Default Re: My wipers don't work! Please help!
Sometimes the wiper arms strip out where they slide over those splines. Are you sure the crank arm is tight on the motor?
Add to bluesl2's Reputation
Old 03-16-2018, 05:35 PM   #3
ratwhisperer
1997 SL1
I think what I've decided to do is just pull the whole thing apart again and retrace my steps of how I put everything back together and make sure I parked the motor correctly, etc... because I pulled the arms off again and now nothing turns at all; so I may just need to exercise more care.
Past:
Current:
Old 03-16-2018, 05:37 PM   #4
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: My wipers don't work! Please help!
https://www.youtube.com/watch?v=b5mh-OrFdnc
See if this is the problem
1995 SL1 234,300 Well Oiled!!
1997 SL1 63,180 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-16-2018, 06:05 PM   #5
hholbein
1997 SW2
+1. I'm assuming with the wiper arms off, can you see the splined posts oscillating? If they aren't moving topside and you can hear the motor running under the cowl, perhaps you popped the motor's bell-crank arm out of the linkage while re-installing?
It's been a few years since I had my motor out (same symptom -- bad motor controller attached to the motor subassembly caused nutso behavior). You might find reinstalling a bit easier in that tight cowl space if you get the motor to stop with the wipers in the 11 to 1 o'clock position.
BTW, when you pull the motor out, it's probably worthwhile to take the linkage apart, clean it up, and lube it properly. It's also a good idea to clean out the accumulated grime in the cowl well and ensure the rubber drain boots at the bottom of the cowl are looking good. After all, as a fellow Oregonian, I assume your wipers are getting a lot of heavy use.
Let us know how you get on.
Add to hholbein's Reputation
Old 03-16-2018, 07:58 PM   #6
ratwhisperer
1997 SL1
Thanks everyone, I'm going to pull it all off again tomorrow and just double check all steps, and I will check to see if the arms are stripped as well. I will let everyone know how it goes. Thank you!
Past:
Current:
Old 03-17-2018, 02:12 PM   #7
ratwhisperer
1997 SL1
Okay here is where we are at today!
So I pulled the whole thing out again (cut myself really good in the process), and I made sure it was parked correctly, the whole bit; tested it. Oscillation was fine. Everything looked great!
Then I put the arms back on again... NOTHING.
And then when I pulled the arms off again, NOTHING.
So I repark the motor, happy day, it works! And then put the arms back on... SAME THING HAPPENS AGAIN.
I thought maybe stripped splines? But why then would it cease to function if I pull the arms back off?
So as long as I don't want wiper arms, I'm golden!
Sigh... :/ What now?!
Past:
Current:
Old 03-17-2018, 02:51 PM   #8
toggenburg
toggenburg's Avatar
The wiper motor pulse board/regulator needs to be replaced. It should be a smallish box right on the motor and it controls all activity IF the motor is not shot. They are not much money.
Edit:
Rats: I cannot locate that part separate from replacing the entire wiper motor.
But that motor is like $58 at autozone.
Old 03-17-2018, 03:08 PM   #9
ratwhisperer
1997 SL1
Okay good to know! I will check that out.
Past:
Current:
Old 03-17-2018, 09:52 PM   #10
JerryHughes
JerryHughes's Avatar
1997 SL
If all else fails, look into getting a better ground. I had the same "crazy" wiper thingy happen to my 97SL which started with the windshield wiper washer not working. I think the ground/grounds for the wipers and the wiper washer are in the same location. After I cleaned it all off, all's fine.
Don't know if this is your problem of course, but here's the post to put in a new ground.
http://www.saturnfans.com/forums/sho...d.php?t=231672
Pic of new ground----
http://www.saturnfans.com/forums/att...5&d=1500736703
and location------
http://www.saturnfans.com/forums/att...4&d=1500736703
Good luck.
Old 03-23-2018, 08:32 PM   #11
ratwhisperer
1997 SL1
Update! So I had a friend who is a mechanic come look at it. All I was doing was not parking the motor correctly. So dumb. I feel so silly! Once he showed it to me it made so much sense. Well, a little bit of a headache but for the cost of a $20 used motor at the pick and pull I will take it!! Thanks all!!
Past:
Current:
2004 Ion wipers work on high only Biff_n Ion Tech 4 02-12-2014 12:21 AM
Windshield Wipers Won't Work, Please Help BeamyUp13 Ion General 13 12-12-2012 03:27 PM
windshield wipers work , but no squirter.. mark rose S-Series Tech 8 03-14-2006 08:54 PM
Windshield Wipers don't work? delturcious S-Series General 5 12-10-2005 02:45 AM
windshield wipers/defroster won't work memphisperson S-Series Tech 6 12-30-2003 12:09 PM
