Old 03-13-2018, 02:53 PM   #1
sczastrow
sczastrow is on a distinguished road
2008 VUE 2.4L
Default Electrical Issue ?
Vue 2.4l XE with 86,000 miles.
Codes P0013 - Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0128 - Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
P0455 - Evaporative Emission (EVAP) System Large Leak
U2105 Lost Communications with ECM
1st P0455 12-18 mon ago - I replaced the fuel cap with a GM cap, replaced the EVAP canister purge solenoid valve, and the EVAP vent solenoid valve. The code would return 3-5 days later each time.
2nd 5-6 mon ago P0128 - I replaced the Engine Coolant Thermostat - went away for awhile but returned.
3rd 4-5 mon ago P0013 - I replaced the Camshaft Position Actuator Solenoid Valve - went away for a while. The code would be intermittent and then return.
4th 1-2 mon ago P0128 - I replaced the Engine Coolant Temperature Sensor - went away for a few days. The code would be intermittent and then returned
I replaced the ECM(Knock Sensor) because all of the devices are controlled by the ECM. I had the ECM programed by a local shop.
5th - U2105 by the time I got home I had the U2105 code. I thought it may have been set because the ECM was replaced, but the U2105 did not set the SEL light.
Three days later P0013 and P0128 set again. A day later P0455 set again.
The only thing I can think of next would be to change the wiring harness for $215. If I take it back to the shop, they $95/hr just to run some diagnostics.
I have had the typical wiring harness problem on the rear brakes and the best thing there was to replace the wiring harness for $30.00.
Add to sczastrow's Reputation
Rate the quality of this post and help sczastrow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sczastrow is offline   Reply With Quote
Electrical Issue and Starting Issue 1995SW2 S-Series General 5 12-02-2015 07:55 PM
electrical issue Packrat1 S-Series Tech 3 06-29-2012 05:20 PM
Electrical issue whitedog59 S-Series General 15 08-06-2011 07:49 PM
Electrical Issue???? liquiddan Vue General 3 02-03-2011 12:30 PM
Electrical Issue with 03 Vue blueroc Vue Tech 3 08-22-2007 09:43 AM
