Old 03-07-2018, 04:35 PM   #1
Johnathan207
Johnathan207 is on a distinguished road
Default Saturn l200 2001
Is the 02 sensor in the catalytic converter or somewhere else I canít find it?
Add to Johnathan207's Reputation
Rate the quality of this post and help Johnathan207 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Johnathan207 is offline   Reply With Quote
Old 03-07-2018, 04:53 PM   #2
Default Re: Saturn l200 2001
There are two O2 sensors, one on the exhaust manifold (possibly hidden by a heat shield) as the precat/main sensor (HO2S-1) and the post cat sensor (HO2S-2) downstream of the catalytic converter.
If there's an error code, what is it?
Old 03-07-2018, 06:37 PM   #3
pierrot
pierrot's Avatar
Welcome to SaturnFans, Johnathan207!
If you're looking for the "Upstream" O2 sensor then look carefully at the connection between the exhaust manifold and the flex pipe segment at the head of the exhaust system. If it's like the one shown in the picture from my car then it is somewhat obscured by the exhaust manifold heat shield. The view is from above and at the driver side.
To find the "Downstream" sensor you'd need to be underneath the car. It's past the converter, pointing outward toward the passenger side.
When removing either of these sensors it is best to tighten it slightly to break seal of the threads. It seems counter-intuitive, but it works. Then proceed to loosen it. You should use an O2 sensor socket for the upstream sensor. It's possible to get by with a wrench on the downstream sensor.
292,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 03-08-2018, 08:57 AM   #4
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Pierrot's Post is spot on.
One suggestion however. Bring your old sensor with you to the part store. When I replaced mine several years ago, the wire on the new one was a little shorter than the OEM. Barely enough room to re-connect it after I re-routed it. I suspect this part is used on other vehicles and is not exactly the same length as the one the factory used. New sensor worked fine as it did turn off my Check engine light.
I think I used a NGK sensor. ( Came in a Bright Green Box) Check on the Bosch or AC Delco to possibly avoid this.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 03-08-2018, 10:37 AM   #5
pierrot
pierrot's Avatar
^Good call, rb6667! That's a really helpful suggestion. I replaced the upstream sensor on my car with a Bosch O2 sensor and the wire length was fine - no problems with fitment of any kind.
Old 03-09-2018, 02:50 PM   #6
rb6667
rb6667's Avatar
^^^ Good to know the Bosch has the correct cable length. I'll know next time when one of my other L's need one.
Thanks for the tip!
2001 Saturn L200 Help! SaturnDriver15 L-Series General 2 05-05-2014 07:59 PM
2001 saturn L200, 2.2, a/c clutch gus55 L-Series Tech 6 08-07-2011 05:33 PM
Need help! Saturn L200 2001 RKE not working vkw619 L-Series General 3 06-11-2011 07:15 AM
2001 Saturn L200 Leo Ladzinske L-Series Tech 0 10-18-2008 01:56 PM
urrggg... 2001 saturn L200 dearan L-Series General 3 11-07-2006 05:17 AM
