Old 03-06-2018, 06:39 PM   #1
Lithgow
Lithgow is on a distinguished road
Default 03 Vue 3.0 thermostat.....while they are in there....
I'm having the thermostat replaced on my 2003 Vue (3.0 AWD). (It had the cold engine code....and temp gauge does seem to stay low) I understand that the intake manifold has to be removed to do this. Any suggestions for other maintenance while they are in there? Also having transmission serviced. I would like to keep this car running as long as possible. Recently I had the timing belt, water pump, and serpentine belt replaced. The car has 154,000 miles on it.
Add to Lithgow's Reputation
Rate the quality of this post and help Lithgow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lithgow is offline   Reply With Quote
Old 03-07-2018, 01:07 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 03 Vue 3.0 thermostat.....while they are in there....
Replace the spark plugs and valve cover gaskets.
Add to bluesl2's Reputation
Old 03-07-2018, 06:45 PM   #3
Lithgow
Ok, will do the plugs as well. Thank you
Old 03-09-2018, 11:58 AM   #4
Cavell
2004 VUE 3.5L
when they remove the plugs they will see inside the plug wells and if there is any oil puddling there than they should change the valve cover gaskets. i have seen several oz's of oil in each well and i cannot believe the mechanic would not mention changing the gaskets than. be warned though, most parts houses do not stock the 3.0 parts. they might have to order them.
Add to Cavell's Reputation
Which Thermostat? Mister_Cee S-Series Tech 3 07-23-2015 12:04 PM
Thermostat? dragonslord S-Series General 7 02-13-2013 01:22 AM
Best thermostat? Vulcansat S-Series Tech 23 01-08-2013 01:16 AM
Thermostat? dragonslord S-Series General 8 12-24-2012 07:42 PM
Bought new thermostat Saturn 2000 SL1 rated at 180*. Is this correct thermostat? 1tallguy S-Series Tech 11 10-25-2011 09:55 PM
