Old 03-04-2018, 05:21 PM   #1
publicvoid
publicvoid is on a distinguished road
publicvoid's Avatar
Default Leaking fuel or
2006 Saturn Vue 2.2L
Got an EVAP code earlier this week P0496 and smelt gas coming from the fuel tank, went to go look under and seen fuel around the tank hose. What caused the leak? Would I need to replace the whole tank? Vehicle does have 218k miles. Has anyone come across this problem? Please Help
Add to publicvoid's Reputation
Rate the quality of this post and help publicvoid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
publicvoid is offline   Reply With Quote
Old 03-04-2018, 08:08 PM   #2
99WhiteC5Coupe
99WhiteC5Coupe will become famous soon enough99WhiteC5Coupe will become famous soon enough
Default Re: Leaking fuel or
The vehicle needs to be inspected closely, probably while on a lift.
I suspect the filler neck (metal) has a hold and/or the rubber connecting hose is damaged.
Add to 99WhiteC5Coupe's Reputation
Rate the quality of this post and help 99WhiteC5Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99WhiteC5Coupe is offline   Reply With Quote
Old 03-14-2018, 11:37 AM   #3
publicvoid
publicvoid's Avatar
It turned out to be one of the hoses connected to the fuel pump module that was leaking fuel, the plastic nipple hoses connects to gets brittle overtime, what a designed flaw by GM. Unfortunately you have to replace the whole pump assembly.
Leaking fuel injector? Rm2011 S-Series Tech 3 07-06-2012 07:52 PM
leaking oil or fuel? turbosaturnsl2 S-Series Tech 3 10-09-2011 06:16 PM
fuel leaking at the fuel rail chet L-Series General 3 05-22-2010 08:53 PM
Fuel injector leaking Dime333 S-Series Tech 4 12-28-2009 04:10 PM
leaking fuel tank... saturn94v S-Series Tech 2 11-03-2008 10:03 PM
