Old 02-24-2018, 09:35 PM   #1
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Default 2006 3.5 Honda cuts fuel off (??) at 3500 rpm
In park AND while driving RPM's hit pretty much exactly 3500 and it feels like a fuel cut off rev limiter. Bounces right around 3500 RPM. Have never had an issue like this until just now. Idles and drives just fine up to 3500 and then what feels like the fuel cutting out to control revs kicks in. Anyone had this issue with their Honda motor before and what was the cause. A little stumped here.
Saturn Vue: The 250 HP tupperware
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 02-24-2018, 10:14 PM   #2
newbievueowner
2006 VUE Red Line
Default Re: 2006 3.5 Honda cuts fuel off (??) at 3500 rpm
So I put the scanner on it and pulled a P2649 code....
Now just to figure out what exactly is bad... lol
Old 02-25-2018, 02:26 AM   #3
pierrot
pierrot's Avatar
I did some searching and found this information regarding a DTC P2649. I hope it will be useful.
https://www.yourmechanic.com/article...by-jay-safford
http://bestride.com/engine-trouble-codes/P2649
https://repairpal.com/OBD-II-Code-P2...l-circuit-high
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 02-25-2018, 08:38 AM   #4
newbievueowner
2006 VUE Red Line
Yea, after doing a bunch of searching on the internet this failure is not that uncommon and it seems that the common causes of this failure code are low oil level, partially blocked VVT filter screen or faulty pressure switch or solenoid. I'll start with cleaning the VVT screen because it's the easiest/cheapest (and almost all others that have replaced the sensors said they had to clean/replace the screen for the problem to finally be fixed) and go from there. I'll post results after the fixes.
For everyone that thinks/says imports are much more reliable, etc that is BS. This Vue has the Honda power train and I've have the most problems with this vehicle in comparison to all my other GM vehicles. Pretty much all the problems/issues/codes have been from the PT....
Old 02-26-2018, 10:37 PM   #5
newbievueowner
2006 VUE Red Line
Turned out to be an easy/simple fix. When I took the front RH tire off and got in there it turned out the wire for the VVt solenoid FELL OUT of the wether pack connector housing. The terminal was damaged during assy from the looks of it as it would not stay in because the retention ears were bent over. Fixed that and now it's back together and locked. RPM's go to redline again, yay. Gotta love the simple easy wins!
2006 ion 3 cuts out while driving slow Fixit007 Ion General 2 12-22-2015 06:18 PM
fuel pump cuts off 96-Sc2 S-Series Tech 7 01-12-2013 01:48 PM
low on power and cuts out at 3500 Firechicken Vue Tech 9 09-09-2011 12:28 AM
Air Conditioning problems affecting Honda Engines (Honda Black Death) tphill5999 Vue General 10 06-01-2010 05:33 AM
Vue 04 Honda fuel filter winter55 Vue General 5 08-30-2008 12:26 PM
