Old 02-23-2018, 10:37 PM   #1
Srjs28
Srjs28 is on a distinguished road
Default Replacing timing set
I have an 05 vue which I am replacing the motor in. The replacement motor has 75,000 miles on it and I have considered replacing the timing set. I went as far as ordering the timing chain set and sprockets. My question is this, how complex of a job is this? The manual I have ( Haynes) isnít much help. Any special tools needed for this job? Anything I need to know?
Add to Srjs28's Reputation
Rate the quality of this post and help Srjs28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Srjs28 is offline   Reply With Quote
Old 02-23-2018, 10:42 PM   #2
Srjs28
Default Re: Replacing timing set
Also Iím not sure what year the replacement motor is or what it came out of. I do know there were issues with the Oiler and tensioner on earlier motors. Is there a way to tell what year motor I will be getting or able to tell if I do have the motor with the timing set issues?
Old 02-24-2018, 02:18 PM   #3
Beasleylou
Beasleylou is on a distinguished road
If you have the motor out it should be relatively simple.
The Cloyes kit comes with good instructions. Even if you don't have the Cloyes kit you can follow their instructions. Should be on their website.
Other than torgue wrenches, I don't recall any special tools.
Should probably do the water pump and thermostat while you're at it.
Add to Beasleylou's Reputation
Rate the quality of this post and help Beasleylou reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beasleylou is offline   Reply With Quote
Old 02-24-2018, 02:38 PM   #4
Beasleylou
There should be codes stamped on the engine where you can determine the year. See attached.
Old 02-24-2018, 08:52 PM   #5
waiter21
2003 VUE 2.2L
I replaced mine a couple years ago.. This should help..
http://www.saturnfans.com/forums/sho...d.php?t=218942
Add to waiter21's Reputation
Old 02-24-2018, 10:33 PM   #6
Srjs28
I wAs looking at the old post when I saw the pics of the tensioners and realized my new kit came with the old style gen 2 tensioner, the one without the o-ring. Is this cause for concern? it also came ďactivatedĒ.
Old 02-25-2018, 05:37 PM   #7
waiter21
2003 VUE 2.2L
I'd prefer the newest style, but the ver 2 should be good for 100k or so.
You should be able to re-cock the tensioner, I'm not sure how to re-cock the ver #2.
Old 03-02-2018, 04:56 PM   #8
stefanP
stefanP is on a distinguished road
I also agree to replace waterpump.Easy with engine out.
Add to stefanP's Reputation
Rate the quality of this post and help stefanP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stefanP is offline   Reply With Quote
Replacing Timing Chain mkorchin L-Series General 2 03-17-2013 01:54 AM
Replacing Timing Chain again!! myolbug S-Series Tech 19 09-23-2009 11:29 PM
Replacing Timing Chain? Generic S-Series Mods 1 05-15-2006 05:17 PM
replacing timing chain 95 SW1 green S-Series Mods 2 02-17-2006 04:59 PM
Replacing Timing Chain poorboy S-Series Tech 6 09-06-2005 01:43 AM
