Old 02-23-2018, 04:21 PM   #1
00_SL1
00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough
00_SL1's Avatar
2001 SL2
Default Wierd occurance after every cold start
Hi all. About two months ago I started noticing my 2001 SL2 5 speed will act like I have slammed on the brakes for a split second within driving the first 100 yards or so. This only happens on a cold engine start, after being warmed up, I can shut it off to run into the library to grab my next hold, or pump some gas, and this doesn't happen. A couple months ago, this was a very seldom occurrence (that I noticed) but this past two weeks, it is every time, every single cold start, and it only happens once then it's fine no matter how far I drive.
I have no codes, no dash lights, all systems normal
Does anyone have any ideas on what I should check, or look at?
01 SL2
04 Silverado
06 Uplander
05 Express
Add to 00_SL1's Reputation
Rate the quality of this post and help 00_SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
00_SL1 is offline   Reply With Quote
Old 02-23-2018, 04:37 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Wierd occurance after every cold start
At 100 yards or so, are you just shifting into second gear, or does there seem to be anything with the clutch n shifting process? How many miles on the clutch and the related parts... throwout bearing n clutch plate?
Old 02-23-2018, 04:42 PM   #3
00_SL1
00_SL1's Avatar
2001 SL2
It happens whether or not i'm shifting, driving in 1st 2nd 3rd ... Miles on car are 168.xxx all original as far as I know
01 SL2
04 Silverado
06 Uplander
05 Express
Old 02-23-2018, 04:55 PM   #4
toggenburg
toggenburg's Avatar
Have you tried letting the car warm up a bit longer before starting out to see if it changes anything?
And does this slamming on of the brakes feeling jerk you forwards in you seat?
Old 02-23-2018, 05:12 PM   #5
00_SL1
00_SL1's Avatar
2001 SL2
I've tried letting it warm up before driving and it still happens. The first couple times this happened it did throw me forward a bit, I wasn't expecting it.
I have tried "spirited" acceleration and it could be all in my head, but I would swear I feel the car hesitate a split second, otherwise not noticeable to speak of.
01 SL2
04 Silverado
06 Uplander
05 Express
Old 02-23-2018, 05:13 PM   #6
00_SL1
00_SL1's Avatar
2001 SL2
It could be the car is feeling a bit of anxiety. The wife and I decided to put it up for sale in January. I can't bring myself to sell it like this without trying to figure it out first.
01 SL2
04 Silverado
06 Uplander
05 Express
Old 02-23-2018, 06:51 PM   #7
toggenburg
toggenburg's Avatar
What is your gas mileage in the city and on longer trips? Has mileage changed recently?
Feeling like the brakes slammed, enough to throw you forward, and now the car acts like it slightly hesitates might be plugs, wires, summat bogging down due to just not warmed up enough...or even the ECTS is bad, that's why mileage questions, and to see if you have an excessively long high idle on cold start.
Old 02-23-2018, 06:56 PM   #8
pierrot
pierrot's Avatar
Does this "braking" problem feel as though it exists in the front or rear of the vehicle?
If this issue was experienced during a test drive it would certainly make the sale more difficult. I believe that you need to correct this problem in advance of selling the car. Based on what you're describing, it seems as if a caliper is temporarily hung up. Frankly, it's not logical, but perhaps the cold weather is generating an "out of the ordinary" braking behavior. At any rate, if this were my car I would look closely at the brakes to make sure they're working as they should and perhaps add some appropriate braking lubricant in the right places.
Another thought just came to mind. There may be an ignition problem. It's possible to have a very brief loss of spark to the engine provide this type of action you're experiencing. It happened with my former spouse's '88 Grand Am 2.3L and it would feel as if there was a brief "jolt" for us in the cabin. It turned out to be a bad coil pack housing which contained the contacts to the spark plugs (in essence, it was like a complete set of ignition wires). I know that your engine's ignition isn't set up that way. I'm merely describing the thing I'd experienced.
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 02-24-2018, 06:32 AM   #9
trottida
trottida's Avatar
This would be a good place to start. I had a similar experience to yours with my 2001 SL1 and it was resolved by replacing the spark plug wires and spark plugs.
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 02-24-2018, 08:20 AM   #10
With 168k miles, well worn parts may be a hidden issue. What's fuel pressure while idling and driving? Tried removing the upstream exhaust manifold O2 sensor to test for a damaged catalytic converter?
Old 02-25-2018, 12:35 PM   #11
Signmaster
One of the members here recently posted about a stumble of sorts at a certain coolant temp IIRC. You might have something similar going on. But my first suggestions would be to check the basics. Sometimes misfires and basic state of tune stuff will be obvious only under certain conditions at first.
Old 05-17-2018, 07:10 AM   #12
00_SL1
00_SL1's Avatar
2001 SL2
Would it surprise anyone to know this problem all but disappeared since it got warm out? I haven't done any troubleshooting, just waited to see if the problem would get worse, but it never did. I have daily driven this to boot.
This morning I let the car run for ~2 minutes, and slowly accelerated and this issue did not occur.
01 SL2
04 Silverado
06 Uplander
05 Express
Old 05-17-2018, 03:18 PM   #13
^ Does this mean we won't hear from you again until next February?
Old 05-17-2018, 03:40 PM   #14
00_SL1
00_SL1's Avatar
2001 SL2
Honestly, it is entirely possible. I am booked with projects this summer so the car is on the back burner. I will keep you posted as much as possible.
01 SL2
04 Silverado
06 Uplander
05 Express
Really, really wierd no start. Growser S-Series Tech 2 09-03-2009 10:22 PM
Wierd start up kingkevin8 S-Series Tech 5 08-13-2009 10:16 AM
Wierd cold start C_Town_Tuner S-Series Tech 2 12-22-2006 06:42 AM
Wierd start-up / idle Static S-Series General 6 10-09-2006 02:04 PM
Wierd VUE Crash Test Occurance... SATURNFAN13185-2 Vue General 14 06-25-2002 07:52 AM
