Old 02-23-2018, 03:26 AM   #1
jtyson
jtyson is on a distinguished road
2008 VUE 3.5L
Default Ironing out various problems
New to me 08 Vue. Technically bought it for my younger sister in college, so trying to get it as reliable as possible within reason on cost for an older vehicle.
Car is an 08 XE 3.5L automatic AWD
Problems I'm dealing with or have dealt with
Bent hood shocks - replaced. Amazon half price of local.
Tires - had 3 different sizes on it so I put a set on.
Rear brake pads low - bought parts still have to install
Oil change - done
Transmission fluid change - bought Dex VI, need to get that done still
Rattle up front - sounds like shock or brake hardware. Need to find and fix
Steering wheel - leather all coming apart so I ordered one from eBay for $35
No heat in cabin - slight smell of coolant so possibly heater core. Hoping not.
Questions for those of you who may be interested enough to read and answer
Heating issue - in the event it is the heater core, can it be accessed from the engine bay? Looks to be an access plate and bolts, but all the threads I've searched say the entire dash must come out.
Rattle up front - anything common? I had an 08 Silverado that the brake hardware wore out on every 10k miles. This sounds a bit worse, but figured it'd be worth asking.
Motor/transmission - is this the Honda combo? I've seen conflicting info and the cap that calls for Dex VI on the transmission makes me think it is not as a Honda transmission would take different fluid.
Add to jtyson's Reputation
Rate the quality of this post and help jtyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jtyson is offline   Reply With Quote
Old 03-11-2018, 10:08 PM   #2
NGFD14
NGFD14 will become famous soon enoughNGFD14 will become famous soon enough
NGFD14's Avatar
2008 AURA XE
2000 SL2
Default Re: Ironing out various problems
With the front end rattle I would suggest that it is eith a sway bar end link or lower control arm.
From what I have read on the heater core, my understanding replacement involves removing the dash and replacing from the inside of the vehicle.
Good luck!
Add to NGFD14's Reputation
Rate the quality of this post and help NGFD14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NGFD14 is offline   Reply With Quote
Old 03-13-2018, 01:48 PM   #3
riprocop
riprocop is on a distinguished road
1993 SW2
1993 SW2
Dash needs to be taken out to replace heater core. If you can do it, I suggest it. Any auto shop will cost you an arm and leg.
2005 Honda Accord EX Sedan White
1993 Saturn SL2 Blue Green
1993 Saturn SW2 Blue Green (sold)
*Yes I did have 2 SW2's of the same color*
Add to riprocop's Reputation
Rate the quality of this post and help riprocop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
riprocop is offline   Reply With Quote
Old 03-13-2018, 02:11 PM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Oil change - done
Yes, the dash must be removed.
You most likely have bad sway bar links. Bad ones often elude good mechanics during inspections.
No the Honda engine/trans combo was only used in the Vue for 2004-2007 models. Your Vue uses a Chevrolet 3.5L/3500 V6 and GM's Hydra-Matic 4T45E transmission.
See responses in bold above.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
5 Speed SL1 with stalling problems and starting problems D.B.Parker S-Series General 11 04-01-2014 12:28 AM
Check engine problems/transmission problems dieseljeepguy L-Series Tech 4 09-18-2012 10:28 PM
P0442 + Ramdon Idle Problems + Random Start Problems craeshe S-Series General 7 09-08-2011 12:27 PM
98 SL2 - new EGR - problems when connected - no problems when disconnected TopherBrowne S-Series Tech 3 08-03-2011 08:43 PM
Transmition Problems? Lower Gears giving problems Juba310 Ion General 17 11-29-2004 05:04 PM
