Old 02-22-2018, 10:19 AM   #1
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Default Inner door panel (card) compatability - 4 door 2nd to 3rd gen
I have a 1997 SW2 and I need to replace my drivers side inner door panel. Are the inner door cards from a 2000-2002 the same? Or do I need 96-99 only?
Thanks!
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 02-22-2018, 02:03 PM   #2
Default Re: Inner door panel (card) compatability - 4 door 2nd to 3rd gen
31 views and no responses?
No personal experience, but found this, post 4 in particular. If you do this, please confirm that it works for future searchers.
http://www.saturnfans.com/forums/sho...d.php?t=157537
Old 02-22-2018, 02:20 PM   #3
I don't think anyone's actually tried it but I believe the entire space frame for '96-'02 4dr's is identical (including doors) so it should fit the door fine. Matching up to the dash and other interior bits is where you'll have issue's.
Composite Door Panel Breaking Loose from Door Frames cvalella Vue Red Line 6 11-16-2013 02:05 PM
how to remove the front door panel on a 2008 3 door astra langisbad Astra Tech 1 02-21-2011 10:52 PM
anyone know how to remove the front door panel on a 2008 3 door astra langisbad Astra Tech 4 01-30-2011 09:41 PM
GEN 2 to GEN 3 Door Panel Compatability geeminator S-Series Tech 7 10-31-2008 09:22 PM
Inside door panel removal? '93 SC2 -- specifically the door handle... benson500 S-Series Tech 5 12-06-2004 07:48 PM
