Old 02-20-2018, 04:54 PM   #1
Jsmith123
Jsmith123 is on a distinguished road
Jsmith123's Avatar
2008 VUE 2.4L
Default Another Vue Heater/AC thread...
I've searched forum and there appears to be a lot of these type of problems...
I just bought an 08 Vue XE, 2.4L 4cyl automatic...
The interior temp controls are acting funny. It's stuck on the "fresh air" (opposed to recirculate) setting. When I press the recirculate button, the light blinks for ~5 seconds and the system stays on fresh air.
It is only blowing out of the main vents, changing the setting to floor or defrost doesn't do anything. No matter what the temperature setting is, it blows cold air (even when the AC button isn't pressed).
The fan speed setting does work... Except for the "off" position, it seems to blow a little bit of air no matter what (not sure if this is just how it works or not).
I've tried the reset procedure (pressing AC/Recirculation buttons 3 times simultaneously) but it didn't work. Research is telling me it's either the controls themselves or the resistors (since it's an electrical system).
Any tips are appreciated. I've ordered the manual but it won't be here for a few weeks.
At this point... Feel like I've had to do everything but replace the engine.
Add to Jsmith123's Reputation
Rate the quality of this post and help Jsmith123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jsmith123 is offline   Reply With Quote
Old 02-21-2018, 01:28 AM   #2
Jsmith123
Jsmith123's Avatar
2008 VUE 2.4L
Default Re: Another Vue Heater/AC thread...
42 views but no replies... Seems everyone is as stumped as I am
Old 02-21-2018, 02:30 AM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Recirculation isn't available when the Mode switch is in Floor, Defog, or Defrost mode.
Disconnecting the battery overnight seems to fix this issue (at least temporarily) for a lot of people. However, in many cases the solution was getting the HVAC control module recalibrated with the latest software at a GM dealership. I've linked a thread for one such instance here.
2007 Ion 2 Quad Coupe 5-speed manual 178K miles
2007 Chevy Equinox LT 187K miles
Add to ruley73's Reputation
Old 02-21-2018, 02:06 PM   #4
Jsmith123
Jsmith123's Avatar
2008 VUE 2.4L
Thanks for the suggestion, something easy to try... I'll disconnect it now and see what happens
Old 02-22-2018, 12:22 PM   #5
Bruce in Montan
Bruce in Montan is on a distinguished road
Cabin air filter clean? It almost sounds like the blend door is stuck open. Just a thought....
Add to Bruce in Montan's Reputation
Rate the quality of this post and help Bruce in Montan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bruce in Montan is offline   Reply With Quote
Old 02-22-2018, 05:12 PM   #6
Jsmith123
Jsmith123's Avatar
2008 VUE 2.4L
Tried disconnecting the battery for ~5 hours, still the same symptoms.
Interesting that you ask about the blend door... I just read elsewhere that the blend door actuator typically fails on these and will cause these types of symptoms.
I'll check the filter, should be getting the manual soon... Hopefully it has troubleshooting procedures
'97 SC2 heater hose removal for heater core flush SC2by2 S-Series General 3 10-24-2015 06:03 PM
Another 3rd gen RKE thread! caveeagle S-Series Tech 2 01-19-2014 03:56 PM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 07:00 PM
New Thread for the New Guy mcguirjf S-Series Tech 0 07-16-2009 10:23 AM
yet another thread jjsk8r85 S-Series Tech 19 02-05-2005 09:15 PM
