Old 02-17-2018, 03:07 PM   #1
ddamian67
ddamian67 has a spectacular aura aboutddamian67 has a spectacular aura about
2001 SL2
1996 SL
Default Power windows motor, 2001 SL2
I have a question both front PWM need to be replaced in my Saturn, what is the recommendation to just buy the motors or the motors with the assembly?
Also any recommendation where to get them other the Ebay so i know i am getting the correct part for my car.
feedback will be greatly appreciated.
regards,
Daniel.
Add to ddamian67's Reputation
Rate the quality of this post and help ddamian67 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddamian67 is offline   Reply With Quote
Old 02-22-2018, 05:38 PM   #2
TomM96
Default Re: Power windows motor, 2001 SL2
Hello Daniel,
it would help to know what car , mileage , symptoms
Did both motors cease ops simultaneously?
In most vehicles, dried up grease on the tracks which comprise the window-lifting mechanism cause excessive friction/drag that overloads the motor, or hand crank.
On our old Saturns, the guides in the doorframe also develop frictional drag which adds to the problem.
I would try a local wrecking yard found thru car-part.com which has same vehicle. The motors tend to be pretty hardy... and junkyards are source of much Ebay stuff. Plus, installation in your car is reverse of removal.
Add to TomM96's Reputation
Old 02-23-2018, 10:52 AM   #3
Telyx
Telyx is on a distinguished road
2002 SL
The switches are also known to go bad after a while. My (now ex-)wife's 2001 SL1 switch cluster has been replaced twice--first with one from a salvage yard, next with her old one which I'd cleaned up. Contacts inside get pitted and carboned up after a while.
RIP my 2002 SL1, totaled 9/18/2012... found its replacement (2002 SL) 9/26/12, traded it in 5/10/2018 (199,604 miles).
Add to Telyx's Reputation
Rate the quality of this post and help Telyx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Telyx is offline   Reply With Quote
Old 02-23-2018, 12:08 PM   #4
trottida
trottida's Avatar
I'm going to guess this is for the 2001 SL2 seeing that is what is in the title and the 96 SL would not likely have power windows.
The part numbers can be looked up on the GM Parts Websites like this one >> Wholesale GM Parts Online.
For the 2001 SL2 the regulator with motor part numbers are
21171231 - Left front door (drivers)
21171230 - Right front door (passenger)
If looking for used you can get from a 1996-2002 S Series Sedan or S Series Wagon donor.
However, as already mentioned, they may not be working for other reasons like the switch pod or the slides. Be sure to test for this before buying parts. The slides are known to break and they are inexpensive to replace. Lubrication of the components also help.
You can use those part numbers to look up on Amazon and eBay for the best price. You can also go to your local GM Dealer or buy from an on-line GM Parts Dealer.
Current rides
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 03-04-2018, 10:02 AM   #5
ddamian67
2001 SL2
1996 SL
Thank you for all the information, i was able to replaced both motors.
First able my local auto part store had the motors in stock, i got them and remove the inner and outer door panels (thanks to Richpin https://www.youtube.com/watch?v=XkfZ...cg80g_v7-KqNr-) and the parts where incorrect so i returned them and look in ebay since i had the part on hand and found them for $29 (new passenger) and $34 (refur. driver).
The windows work perfectly now.
2001 SL2 - power mirror and locks don't work but power windows work vikasevan S-Series Tech 6 03-31-2016 04:55 PM
Convert 2001 SL1 to power locks and windows srowley S-Series Mods 1 07-03-2012 11:58 PM
Stuck trying to replace Power WIndows motor bdmeyer L-Series Tech 8 03-27-2009 06:47 PM
2001 LS300 With Power Windows Rear Door Panel Disassembly somnambulist L-Series Tech 0 12-29-2008 04:14 PM
Power windows motor CAN be changed w/o regulator removal. rearviewmirror S-Series Tech 21 06-15-2007 10:52 AM
