Old 02-17-2018, 01:54 PM   #1
rbar
rbar is on a distinguished road
Dizzy I know, dumb question...
Dumb question I know, but I forgot how to reset the oil light. The 98 SL does not have the oil reset button in the fuse box...HELP!
Thanks in advance!
Add to rbar's Reputation
Rate the quality of this post and help rbar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rbar is offline   Reply With Quote
Old 02-17-2018, 02:23 PM   #2
Jaegweir1259
Jaegweir1259 will become famous soon enough
Jaegweir1259's Avatar
2002 SC1
Default Re: I know, dumb question...
a 98 sl should have the red button "Oil-R" under the hood fuse box
1. Remove the instrument panel fuse box cover (fuse box located under hood on Saturn)
2. With the ignition switch in the ON position, depress the Oil Reset button for five seconds
3. The change oil lamp should then go off
2002 Saturn SC1, Orange, 1.9L L4 EFI/OHC
Add to Jaegweir1259's Reputation
Rate the quality of this post and help Jaegweir1259 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jaegweir1259 is offline   Reply With Quote
Old 02-17-2018, 03:54 PM   #3
The S-series models up to '99 do not have body control modules hence no oil change indicator or oil reset button. All Saturns from model years 2000+ have BCMs, an oil change indicator and reset button in the main fuse panel.
Old 02-17-2018, 07:28 PM   #4
rbar
No sir, it does not. Too early for it. Maybe it was not such a dumb question.
Rbar
Old 02-17-2018, 07:30 PM   #5
rbar
Ooooook. So, what's the answer??????
Rbar
QUOTE=fdryer;2265926]The S-series models up to '99 do not have body control modules hence no oil change indicator or oil reset button. All Saturns from model years 2000+ have BCMs, an oil change indicator and reset button in the main fuse panel.[/QUOTE]
Old 02-17-2018, 08:32 PM   #6
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
If you still have an oil light lit on your dashboard, pull out the dipstick and see if there is any oil in your engine. Adding oil, and starting the engine SHOULD extinguish that dashboard light...is this your real question, red light on the dash?
If not, then fdryer clearly answered your original question.
Your car does NOT have an oil reset button.
Only the Gen 3 do, and those models start with the year 2000.
Old 02-17-2018, 09:05 PM   #7
rbar
Thank you for your condescending reply, worthless as it is.
It does NOT have an oil reset button, but I have reset before, just forgot how. Obviously, noone responding knows how either...
Old 02-17-2018, 09:41 PM   #8
You're the one wanting to reset something that doesn't exist on '91-'99's.
If the red oil can light is on on the dash, that's not a "change oil" light that's generally a "change engine" light.
Old 02-17-2018, 10:06 PM   #9
rbar
Wow, this forum used to he a place,tomfind answers, not condescending Torts...
Duhhh...thanks again for restating the obvious.
Are you drunk and not understand the question???
Old 02-17-2018, 10:07 PM   #10
rbar
Don't bother with another reply if you cannot assist, thanks.
Old 02-17-2018, 10:15 PM   #11
rbar
Just say I DON'T KNOW, if younare clueless, dude.
Regards.
Old 02-17-2018, 11:27 PM   #12
So which one of these lights in the gauge cluster is making you think there's an OLM to reset?
Old 02-17-2018, 11:31 PM   #13
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Regards.
I've travelled these boards for years, seen all sorts of people, good and bad. I've never felt the need to say this before, but out of all the good honest, hard working citizens that frequent this site, I hope none of them help you with your disgusting attitude. We all make our beds in life and you've just made yours
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 02-18-2018, 08:30 AM   #14
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Regards.
You're the one that's clueless. A red oil light on a 98 "S" is NOT an oil change light it's a WARNING that something is SERIOUSLY wrong. In your case both with the car and the driver LOL
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Old 02-18-2018, 05:09 PM   #15
bumpdraft
bumpdraft's Avatar
1998 SW2
You can write the mileage in the owner’s manual in the glove box.
And,
What I do is write the “NEXT @ mileage” on the top of a Post It Note, cut that part off and stick it on the horizontal surface immediately below the fuel gauge.
For example, “NEXT @ 222,600 mi” written on a 100% sticky-backed piece of Post It Note.
Can’t miss it, especially if you are concerned with the health of your piston rings and timing chain.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 02-18-2018, 05:43 PM   #16
dummo
dummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nice
dummo's Avatar
1997 SW2
Please take a photo of the ‘change oil’ message or the indicator light and post it here.
Has this been resolved?
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 02-18-2018, 08:20 PM   #17
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
*knocks back 5th shot of Gin*
Time to be condescending to people in a car forum!
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-182k currently (May 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is online now   Reply With Quote
Old 02-18-2018, 10:28 PM   #18
Saturn Night
https://carhowto.com/how-to-reset-ch...urn-sl-series/
Here is a link, with the instructions on how-to reset the oil change light on a Saturn S-Series.
As you find, in the instructions, this is ONLY APPLICABLE for the 2000-2002 Saturn S-Series.
The users have previously advised you, of this fact, and your overall attitude towards them was quite unprofessional and I felt you were downright offensive.
GM did not start using Body Control Modules, on ANY product lines, until the 2000 model year.
This light, as well as the "Service Wrench/Service Vehicle Soon" & Security lights are triggered by the BCM.
A 1998 Saturn S-Series does NOT have a BCM, and thus this light will never turn on. It is even more difficult to turn this light on, with a 1998 cluster, due to the fact that there is no bulb installed into the socket.
GM used a production process, in the 1990s, called "de-contenting". The process reduces operating costs, by manufacture of certain parts of the car(such as gauge clusters) to have all the fittings for every feasible option(my 1995 SC2 cluster has the socket for the Service Wrench, but no bulb installed into it), and where the options are not added, rubber and plastic plugs were used to fill in the holes.
This process is obviously evident, when comparing center consoles of the second gen interior:
Power windows are controlled from the same slot, that is replaced by a plastic filler piece that is just large enough to hold a cellular telephone or a small book.
With all that being said, cut the attitude problem and show these people more respect for being polite in their initial responses.
It is a natural human reaction to come off with an attitude, after somebody behaves disrespectfully towards them.
Saturn Night is online now   Reply With Quote
Old 02-19-2018, 10:17 AM   #19
dummo
dummo's Avatar
1997 SW2
Originally Posted by jonasan308 View Post
*knocks back 5th shot of gin*
time to be condescending to people in a car forum!
lol ! ! !
Old 02-19-2018, 09:33 PM   #20
Jaegweir1259
2002 SC1
I was wrong, and was corrected , Thank guys, now I know. LOL
I wonder where he went? maybe realized he actually needed oil?
Horn question...(Possibly a dumb question) ninetynineSC2 S-Series Mods 8 02-18-2013 09:01 PM
Dumb Oil Question... oceanjoe89 S-Series Tech 3 06-29-2006 04:09 AM
Dumb question... andie Vue General 9 12-12-2005 06:03 PM
Dumb question basmoq S-Series Tech 10 04-19-2005 08:30 AM
Probably a dumb question...but here it goes... TheGame983049 S-Series General 9 01-09-2004 11:51 PM
