Old 02-17-2018, 12:45 PM   #1
coge4419
coge4419 is on a distinguished road
Default Dropping Rear Wheel Drive Diff
Iím stuck currently in removing the entire rear end diff assy on my 06 Vue. Iím struggling in separating the axles off the diff to remove two mounting bolts to allow the whole unit to just fall off.
Add to coge4419's Reputation
Rate the quality of this post and help coge4419 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coge4419 is offline   Reply With Quote
Old 02-17-2018, 01:34 PM   #2
coge4419
Default Re: Dropping Rear Wheel Drive Diff
Well I got it. I was trying to avoid taking the rear bearing off. But thatís what it took. Once bearing was off, I slid axle out and can drop rear end.
Old 02-17-2018, 05:18 PM   #3
atikovi
Won't the rear wheels fall off without the axle shafts and nuts keeping the bearings together?
Add to atikovi's Reputation
Old 02-17-2018, 08:49 PM   #4
coge4419
Nope. The rear bearings are no different than the fronts. However more so the part number for a gm was bearing or a front wheel drive rear bearing is the same. I finally got everything dropped and the car is so much quieter without the worn out diff in the back
Old 02-17-2018, 09:11 PM   #5
atikovi
Ok, I was reading the service manual of another GM model which said not to move vehicle on it's wheels if the drive axle is removed from the hub. Vue may be different.
Rear wheel drive conversion Red_Ninty_9 S-Series Mods 21 07-30-2011 12:21 AM
Rear Wheel Drive Assist 1saxman Vue General 46 01-05-2010 12:31 AM
Rear Wheel Drive!!! Grim_fandango S-Series Mods 24 08-24-2006 09:30 PM
Rear wheel drive stlouis1997sl S-Series General 3 06-11-2006 04:44 PM
sl rear wheel drive stlouis1997sl S-Series Mods 13 03-07-2006 02:08 PM
