Old 02-16-2018, 09:52 PM   #1
Twig
Twig is on a distinguished road
Default 2005 vue, 2.2L manual issue revving
hello all, help with this issue would be much appreciated, have had it to the mechanics and no help
Here is my issue, i purchased a 2005 saturn vue, 2.2L manual. previous owner had a motor transplanted into it, motor was from an 06 2.2L.
The car will not rev past 2000 rpm, check engine light is on for o2 sensor. replaced throttle body and still having the same issue. no low power light is on but it does work! not sure if it would be related but the speedometer is also bouncing all over and adding km's. mechanic said his scanner isn't throwing any other codes then the one i am currently getting.
Add to Twig's Reputation
Rate the quality of this post and help Twig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twig is offline   Reply With Quote
Old 02-17-2018, 09:41 AM   #2
waiter21
2003 VUE 2.2L
Default Re: 2005 vue, 2.2L manual issue revving
Clean and check electrical grounds. A bad or missing ground will cause this.. Remove the ground use a wire brush, sand paper, etc to clean the connector and the ground surfaces.
Add a couple extra ground wires.
Look at the link. I had the same problem..
http://www.saturnfans.com/forums/sho...d.php?t=216101
Add to waiter21's Reputation
Old 02-17-2018, 10:45 AM   #3
Blocked exhaust system? Mileage when the engine was replaced?
Old 02-17-2018, 11:36 AM   #4
Twig
Okay I will check my grounds again. I cleaned 3 under the hood previously, and the Exhaust I believe is factory, car has 210 thousand km's.
Old 02-17-2018, 03:35 PM   #5
Twig
I have cleaned all grounds, also ran extra's as suggested. No change.
Running sea foam in it right now to see if it changes anything
Old 02-17-2018, 09:02 PM   #6
Twig
Sea foam did not work. Possibly cutting the cat out to see if it changes, doubtful though. When I bought it the exhaust was already off and had the same issue, originally thought it was because of no back pressure. Could an over heated engine cause this? Bcm of ecm malfunction? Throttle plate not registering gas peddle properly? if so how could I relearn the ecm
Old 02-18-2018, 04:17 AM   #7
You can remove the exhaust manifold mounted O2 sensor (upstream from catcon) to allow an alternate exhaust hole before the catcon and drive around. While loud, either engine power is suddenly restored or remains same. You may have to make a soup can diverter to direct hot exhaust gases away from any nearby plastic from melting while performing this test. If engine power returns, the catcon is clogged. Most EFI systems do not have any back pressure. 0.5 psi is considered factory back pressure.
Old 02-18-2018, 01:34 PM   #8
Twig
Exhaust isn't the issue. Probably sending it to scrap. Thanks for the help
2005 Vue 2wd 2.2L manual shifter cable issue. topCONsurveyor Vue Tech 2 05-21-2012 12:46 PM
2005 VUE 2.2L A/C Issue wattstopper101 Vue Tech 2 08-16-2010 05:47 PM
04 Ion revving issue ariesdragon Ion Tech 4 05-17-2008 01:29 PM
2005 Vue manual msgrape Sky Tech 1 06-24-2007 01:51 PM
Revving Issue (kinda long) nj96 S-Series General 4 03-11-2004 01:12 AM
