Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 02-13-2018, 08:00 PM   #1
blaster88
blaster88 is on a distinguished road
2004 VUE Red Line
Default That carrier bearing...
Obviously AWD.
I have some driveline shudder - the PO put on a brand new set of wheels and tires so I don't suspect wheels out of balance but cannot rule that out yet. (I may rotate them to see if that makes a difference.)
But it feels kind of like an AWD Bravada I had did when the drive shaft went bad (totally different technology but it reminds of the way that felt - it isn't constant, sometimes you don't even feel it.)
Anyway, I got under it and tried to move the drive shaft in the carrier bearing - and it does move some. It is NOT as bad as the Youtube's out there that show a totally failed bearing that clanks around inside the metal bracket - but it moves about a 1/4 inch. I am not sure if it should move at all - it is a rubber gasket so it would make sense if it moved some, but I think it is a hard rubber.
Thoughts?
Add to blaster88's Reputation
Rate the quality of this post and help blaster88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blaster88 is offline   Reply With Quote
Old 02-13-2018, 08:43 PM   #2
atikovi
Default Re: That carrier bearing...
Remove the driveshaft assembly and go for a drive. If the shudder goes away, you know what to concentrate on.
Add to atikovi's Reputation
Old 02-20-2018, 06:50 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...AND IF YOU DO NEED A DRIVESHAFT, AND HAVE A FEW BUCKS, GO WITH A DRIVESHAFT FROM SHAFTMASTERS. IT IS A HIGH QUALITY BUILT UNIT , GETS RID OF THE CV END AND REPLACES IT WITH A SLIP JOINT, SHAFT IS BEEFIER ALSO, ALONG WITH BETTER U JOINTS, JUST MY .02, DC
Add to Vue6's Reputation
Old 02-20-2018, 07:27 PM   #4
oldmanina2005vu
oldmanina2005vu will become famous soon enough
2008 SKY Red Line
I see you live in Northern VA. Take the drive shaft out and throw it away. It's going to fail anyway. Remove the rest of the rear drive train at you convenience.
Add to oldmanina2005vu's Reputation
Rate the quality of this post and help oldmanina2005vu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oldmanina2005vu is offline   Reply With Quote
Old 02-20-2018, 11:29 PM   #5
blaster88
2004 VUE Red Line
I see them for ~$650? Tha's kind of a yikes.
Old 02-20-2018, 11:31 PM   #6
blaster88
2004 VUE Red Line
We had snow and sleet Saturday and the AWD helped.
When I test drove a FWD in the rain too easy to spin the wheels - decided AWD is a must.
YMMV.
Old 02-21-2018, 06:45 PM   #7
Vue6
Vue6's Avatar
2006 VUE Red Line
...The driveshaft from shaftmasters is well worth the money, compared to the junk factory shaft and other makers on ebay of a stock type one . the shaft alone is bigger and more hd. Look closely at the pics of a shaftmasters one. There is no comparison. Great cust. service also, just my.02, DC
03 AWD Carrier Bearing??? tomn1437 Vue Tech 11 09-09-2015 11:12 AM
06 Vue RF cv axle carrier bearing? BrianKM Vue General 15 12-08-2014 08:38 PM
Carrier bearing? york21165 S-Series Tech 3 05-11-2011 09:07 PM
2003 Carrier Bearing tomn1437 Vue Tech 2 12-02-2010 10:30 AM
AWD Carrier bearing? 02VueBeater Vue Tech 3 04-01-2006 10:09 PM
