Old 02-13-2018, 04:28 PM   #1
Bean Jovi
Bean Jovi is on a distinguished road
Wrench Help With Locating a Part
Alright, my 08 Vue needed a new EVAP canister, but I only later found that one of the lines that connects into the canister is broken. I canít find the part for the life of me, but found a diagram with the part needed on it. The part needed is labeled ď1Ē and any help in locating a replacement part would be greatly appreciated!
File Type: jpeg 1CC0B929-C71B-4732-91EF-5C92157D5FCE.jpeg (140.4 KB, 16 views)
Add to Bean Jovi's Reputation
Rate the quality of this post and help Bean Jovi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bean Jovi is offline   Reply With Quote
Old 02-13-2018, 10:52 PM   #2
Bean Jovi
Default Re: Help With Locating a Part
Here's a better image, part 4 toward the top. wholesalegmpartsonline(DOT)com/images/parts/gm/fullsize/100706ZL03-138.JPG
Old 02-14-2018, 08:09 AM   #3
waiter21
2003 VUE 2.2L
Mine were rusted out. I replaced them with hose.
My fuel line and the canister lines were both rusted. I replaced the fuel line with high pressure hose and fuel line clamps. I replaced the vacuum line with OEM style nylon hose, but regular fuel line hose would work.
I cut the connectors off the ends of the old lines and re-used them on the new lines.
Check out the link. there are some photos there also.. Scroll down to post #9
http://www.saturnfans.com/forums/sho...d.php?t=215542
Add to waiter21's Reputation
Old 02-15-2018, 01:22 PM   #4
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
Try ACDelco 22803865
Add to JefferyC's Reputation
Rate the quality of this post and help JefferyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JefferyC is offline   Reply With Quote
Old 02-15-2018, 04:28 PM   #5
Bean Jovi
Similar, but donít think itís that part. I tried to get as best a picture I could without putting the car on jacks. Maybe it helps.
File Type: jpg 7940F249-079D-4697-80D7-A7F3AB6EA512.jpg (92.5 KB, 8 views)
File Type: jpg 80D7E31F-E7A4-470D-9E4B-21627D63C9B3.jpg (152.7 KB, 8 views)
Old 02-16-2018, 10:32 AM   #6
JefferyC
JefferyC's Avatar
Go to Rockauto.
Help locating part for upper latch tether for child seat specs S-Series General 10 06-11-2011 05:42 PM
Problem Locating Part for 2001 Saturn L300 Saturn2001L300 L-Series General 1 06-07-2011 06:43 PM
Questions about locating PCM & BCM AnthroGal S-Series Tech 16 09-30-2008 10:17 PM
Help Locating ECTS Eagles Vue Tech 1 12-08-2007 01:01 PM
help locating nmatcek S-Series Tech 1 03-19-2006 09:10 PM
