Old 02-12-2018, 11:46 PM   #1
eclipsor
eclipsor is on a distinguished road
Default holes in spare tire well
hey everyone, just discovered a oil leak under my trunk and realized one of my gallons of oil in my trunk must have been leaking out of these two holes under the spare tire
are these holes supposed to be here?
i.imgur.com/2NlxKpa.jpg
Add to eclipsor's Reputation
Rate the quality of this post and help eclipsor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eclipsor is offline   Reply With Quote
Old 02-13-2018, 01:22 AM   #2
Default Re: holes in spare tire well
Yes & no.
Yes they're supposed to be there, no they're not supposed to be unplugged like that.
I don't know their intended purpose, I suspect it's either for air flow out the back of the car or water drainage.
Old 02-13-2018, 04:39 PM   #3
eclipsor
Originally Posted by fetchitfido View Post
Yes & no.
should i just leave them like that then? thank you!
Old 02-13-2018, 06:16 PM   #4
floridasl22002
floridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to behold
I think they have as a rssult of maybe the press process during manufacture. They usually have a metal plug fitted. If you havern't got those, then just pop some duct tape over them on the inside of the well. That should stop things going out AND coming in.
Old 02-14-2018, 11:17 AM   #5
TomM96
My '96 SL, And my '97 SW both had leaky trunk/liftgate(s).......
Better to leak than rust through !
Add to TomM96's Reputation
Old 02-14-2018, 05:52 PM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
^Yes^ smear the duct tape with WindoWeld.
Those openings could be to locate the panels for the stamping press and the robot welders and to drain the electrified E-coat after the entire body assembly gets dipped.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 02-14-2018, 08:36 PM   #7
Jaegweir1259
Jaegweir1259 will become famous soon enough
Jaegweir1259's Avatar
2002 SC1
Yes & no.
The intended purpose is for when you need to clean the Spare wheel well so it can drain, must put them back in when done can cause some rust issues
2002 Saturn SC1, Orange, 1.9L L4 EFI/OHC
Add to Jaegweir1259's Reputation
Rate the quality of this post and help Jaegweir1259 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jaegweir1259 is offline   Reply With Quote
The Spare Tire? Janitor Tzap S-Series Mods 10 11-09-2013 12:43 PM
Spare tire DanB98TJ S-Series General 62 01-08-2012 11:45 PM
Spare tire MikeNW S-Series General 12 07-15-2009 02:07 AM
Can you put a spare tire in? BlueBomber6 Aura General 2 08-27-2007 08:10 PM
Spare Tire Druce Vue General 10 07-19-2004 09:45 PM
