Old 02-09-2018, 02:23 PM   #1
mlb007
mlb007 is on a distinguished road
Default dead engine :(
My sons 2001 L200 (mom bought new) died from the timing assembly failure.
Valves are damaged but piston apparently ok.
I figured rebuild the head or buy a new one, but then in reading it seems like lots of problems and recommendations to not go that route.
Is there valid reasons to not just have the head rebuilt?
We kind of decided a re-manufactured engine made the most sense since he hopes to keep it for a few years, but nobody seems to re-man these motors that I can find. (Anyone?)
Car is in very good otherwise with about 90k miles.
Any good advise appreciated, it's been parked a month already while I try to figure out what to do and i've been too dang busy to spend much time on it.
Add to mlb007's Reputation
Rate the quality of this post and help mlb007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlb007 is offline   Reply With Quote
Old 02-09-2018, 07:09 PM   #2
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
2002 L-Series 2.2L Sedan
Default Re: dead engine :(
I don't know where you live, but search car-part.com and you should find many used engines. These little 2.2 motors can hit 300k easily with good maintenance.
Add to soulsurvives's Reputation
Rate the quality of this post and help soulsurvives reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
soulsurvives is offline   Reply With Quote
Old 02-09-2018, 07:43 PM   #3
mlb007
At 1,000 to buy, $1250-1500 to install, plus all the needed parts and the updated timing assembly, I'm not loving the thought of paying 3k for someone else's boneyard ???
Old 02-09-2018, 10:24 PM   #4
bluesl2
bluesl2's Avatar
I just thought I would throw this idea out there. Some of the 2001 model year L-series with the 2.2 ecotec had a recall on them for timing chain issues. You may want to call your nearby GM dealer(have your VIN number handy for when they ask for it), then they will be able to tell you if it is in the recall or not.
Add to bluesl2's Reputation
Old 02-10-2018, 10:19 AM   #5
floridasl22002
Right now the car is a very good boat anchor and worth a lot less than $800.00 or so. Aside from the emotional appeal of the vehicle, you simply have to do the math and work out whether it is economically feasible to spend nearly $3000.00 on a 17 year orphan vehicle that parts are getting scarcer and scarcer for.
$3000.00 would get you something a lot newer. As your son has the car, what does he want to do?
Old 02-10-2018, 11:07 AM   #6
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
I spent about $700 on parts to repair the last L200 with a broken chain. I replaced all the valves, main chain kit from cloyes, just the guides and tensioner and chain for the balance shaft, water pump, some coolant hoses, thermostat, plugs and boots. Donít buy the cheaper gasket set, I had to replace the valve cover gasket after 10k miles. I bought all the parts through Rock auto and did the job in my shop. I replaced all the torque to yield bolts so be sure to get those also. This car is my grand daughterís college daily driver now.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 02-10-2018, 02:20 PM   #7
mlb007
No it won't. Been watching craigslist for the past month with that idea. Anything newer ($4500 or less) has more miles and/or in worse shape.
Been doing the math and that's why we are fixing it.
Car was my moms since new, babied and always maintained. 90k miles is roughly 5,000 miles a year and the body looks like new. It's also a loaded car (for the time) with leather that looks like new, sunroof, heated seats, etc.
Add in that mom died last year and we all (him included) would like to fix it and keep it. For reasons both emotional and totally logical.
I've seen plenty of Saturns with 200k+ miles, so it's not silly to think of fixing it.
Are there any ex-Saturn mechanics on here?
Old 02-10-2018, 02:28 PM   #8
mlb007
First thing we checked. Only includes specific months of manufacture in 2001!!
His not in it.
Old 02-10-2018, 05:24 PM   #9
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
IMHO, I would repair the existing engine considering this vehicle has such low mileage.
Just be VERY sure there is no piston damage or other hidden damage before you go this route.
02 LW300 Outlines what needs to be replaced. His post is spot on!
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 02-10-2018, 08:22 PM   #10
pierrot
pierrot's Avatar
FWIW, I'm in full agreement with the two previous posts by 02 LW300 and rb6667. Of course, moving forward with a potential repair as suggested requires the removal of the cylinder head so as to verify the condition of the pistons.
300,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 02-10-2018, 10:22 PM   #11
02 LW300
02 LW300's Avatar
They use these engines in many GM car lines. So donít just look for a Saturn mechanic. I repaired my own car but I am a professional mechanic. These engines are easier to repair than the Ford Diesels I work on daily. I also have a hoist, all the tools and a complete set of factory service manuals for the L series. With shop rates around $100 per hour the repairs will be expensive.
I purchased a very nice mid level trim 2002 L200 for $300. I bought this car knowing the chain was broken and the extenuating damage caused by this type of failure. I agree these are nice cars, my daily driver is a 2002 L200 stick high line trim. I donít know what I would rather drive, I will drive this car for years to come.
Old 02-12-2018, 01:58 AM   #12
mlb007
Thanks all for the input. Had the car towed to a competent home garage mechanic. He's pulling the head to see what damage and will repair if pistons are ok.
If not, we've found a low mileage, rear ended L to buy the whole engine out of.
He says cost would be about the same either way, more labor with the repair, more parts costs with the swap. $1500ish either way.
I'll be happy if we get it done well and good for that.
Old 02-12-2018, 09:22 AM   #13
rb6667
rb6667's Avatar
^^^^^ Sounds like a great plan. Keep us posted on the progress.
Old 02-17-2018, 03:02 PM   #14
mlb007
Update: Head was trashed and pistons nicked so purchased a 47k(!) (claimed) engine and its being shipped. Old engine is out, mechanic servicing transmission and brakes and cooling while we wait.
Will be replacing water pump and all belts and hoses and such.
Assuming this has original timing chain setup and not the revised 2004+ setup what parts need to be replaced specifically? What got changed? Tensioner or something? Want it fixed from the get go.
Anything else to consider?
Old 02-17-2018, 03:31 PM   #15
rb6667
rb6667's Avatar
If it were me, I'd replace the timing chain and tensioner BEFORE it is installed. It's apparent you want to do this right. Peace of mind goes a long way here.
This assumes this engine is a pre-2004 engine. Do you know if the used engine came out of a L-Series vehicle?
If not, what year and model did the engine come from?
Old 02-18-2018, 03:53 PM   #16
pierrot
pierrot's Avatar
I could not agree more! Having only minimal knowledge of this replacement engine's history you should do all that you can to ensure that it will be as trouble free as possible.
Old 02-18-2018, 04:58 PM   #17
PaulGraz
PaulGraz is a jewel in the roughPaulGraz is a jewel in the roughPaulGraz is a jewel in the rough
PaulGraz's Avatar
2001 L-Series 2.2L Wagon
Just chiming in - I think you made the right choice by finding a low mileage engine and swapping it in. Junkyards are full of low mileage cars, you just have to find the right one.
Our 2001 LW200 is now at about 255K. Yes, ours was part of the recall, so we got a new timing chain around 130k miles. There were no signs of anything going bad, but the dealer called us and said bring it in for the recall, so we did.
Good luck with the new engine!
~Paul
2001 LW200 (4th saturn owned) 260K+ Miles!
71 Volvo 1800E, 73 Volvo 1800ES, 08 Volvo C30, 11 Volvo V50
Gone on to other owners: 92 SL2, 95 SW2, 96 SC2
Add to PaulGraz's Reputation
Rate the quality of this post and help PaulGraz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PaulGraz is offline   Reply With Quote
03 vue 3.0 engine dead Russtoy Classifieds 0 01-07-2014 09:50 PM
2002 Vue AWD 3 Liter Auto - Dead, Dead, Dead ... HELP LinWinux Vue General 6 09-10-2013 03:20 PM
Need Engine Rebuild Help for dead '93 SL2 Darksaber 3 S-Series General 3 11-01-2011 11:58 AM
2000 Saturn LS1 - Engine dead, should I buy rebuilt engine? mattreaton L-Series General 1 05-08-2009 05:14 PM
SL2 engine dead at 85K? andybot2000 S-Series Tech 49 02-08-2005 03:20 AM
