Old 02-08-2018, 09:28 AM   #1
derost
derost is on a distinguished road
Default P0017 Error: which bank is "B"
Hey there,
I've got the dreaded "P0017 Crankshaft Position Camshaft Position Correlation Bank 1 Sensor B" error on my '07 POS Aura XR.
I put in a new sensor and the CEL was off for a couple days and now its back. I am questioning if I put it into the correct spot. I installed it in the lower left, closest to the belt. What I labeled "B" in the photo.
Did I install it in the wrong one?
I am praying that I did as I can't have this be a timing chain issue as the car is only worth $800-$100 on trade in, and I just had to put $500 in suspension, and now the steering pump is notchy. I'm hoping a flush with royal purple will cure that... for a while.
Your thoughts and advice is greatly appreciated...
- Doug
Add to derost's Reputation
Rate the quality of this post and help derost reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
derost is offline   Reply With Quote
Old 03-22-2018, 10:55 AM   #2
<<Aura_XR>>
<<Aura_XR>> is on a distinguished road
2007 AURA XR
Default Re: P0017 Error: which bank is "B"
We've got 175,000 plus in our 07 XR. Exact same code. I have thought about replacing that sensor but many times on here I read that it doesn't resolve the issue. I check the CEL code with my scanner and just clear it. Sometimes if the code is not present, I'll rev the engine a little at first start, keep it around 1500-2000 rpm for a minute or two. Either coincidence or luck, this seems to help for a few days.
Bought the car last year from my neighbor for $3,000. Have replaced shocks, struts, intermediate steering shaft, tires and spark plugs. There is a bit of a stutter at idle from the engine, probably why the code. Last night we were plagued by the brake lights on all the time/no cruise which pulling and reseating the blue connector in the panel on the passenger side of the console fixed.
I too cannot see spending $3,500 to replace the timing chain system. What a shame since the car otherwise is in great shape, great first car for my new driver. When I had my SC2, a used engine swap wasn't a fear but I'm bound to not get that with these 3.6 VVT engines. My wife's cousin's Traverse had the engine blow up on hers and spending $6,000 for a new engine was not even considered. It had the same 3.6 VVT as well.
Add to <<Aura_XR>>'s Reputation
Rate the quality of this post and help <<Aura_XR>> reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
<<Aura_XR>> is offline   Reply With Quote
P0301 Error and Slight "put put" oreoucky S-Series Tech 3 04-29-2012 12:27 PM
I'm Getting a "Read Disc Error" on Navigation ZMonet 2008 Vue 2 06-14-2010 08:31 PM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 12:35 PM
Code "running lean bank 1 and 2" KRStamm Sky Tech 8 04-17-2008 01:18 AM
LC1 spontaneous "Error 8" bc3tech Ion Tech 0 02-13-2007 12:26 PM
