Old 02-06-2018, 02:08 PM   #1
MarcusJennings
MarcusJennings is on a distinguished road
Default TPS for Aura 2007?
Does anyone have experience replacing the TPS on this vehicle?
Add to MarcusJennings's Reputation
Rate the quality of this post and help MarcusJennings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MarcusJennings is offline   Reply With Quote
Old 02-06-2018, 02:42 PM   #2
Default Re: TPS for Aura 2007?
I don't. Mine is fixed (L300) possibly due to being a first generation electronic throttle body. Images from rockauto show yours (3.5L or 3.6L) shows your tps as replaceable with removable clips for removing and replacement. The tps, black plastic part with new clips. Unless there are specific procedures with pertinent info about alignment between the tps and throttle body, this may be a simple repair. At best, searching for online how-to's or repairpal may help otherwise subscribing to alldata for service manual procedures will give more info, especially if a relearn procedure is needed (computer routine to learn new tps values). Drive by wire systems relies on precision communications between throttle and ecm, pedal to ecm. My L300 requires a relearn procedure (done at home) if the pedal or throttle body is replaced.
Any error codes pointing to tps fault or compelling reason to replace it?
2007 Aura XR Key Fob BillinSprings Aura General 12 10-14-2010 05:00 PM
New guy. New (used) 2007 Aura XR jimmyfloyd Aura General 7 03-03-2010 11:07 PM
2007 Aura XR vs 2007 Passat 3.6 VR6 Seasoned Aura General 5 12-09-2006 04:12 PM
2007 Aura XR vs 2007 2.0T passat sedan, which to buy? fantarain Aura General 43 11-26-2006 12:39 PM
2007 SKY or AURA? brianottis S-Series General 9 04-06-2005 07:39 PM
