Old 01-27-2018, 03:06 PM   #1
Nighthawk42472
Nighthawk42472 is on a distinguished road
Default 07 Saturn aura obd2 not working
My daughter has a 07 Saturn Aura that had the typical dead radio problem so I put in a aftermarket radio which works fine but after I put the radio in the obd2 doesnít work anymore. When I plug in my scanner it starts reading and then it comes up and says itís not connecting. I read somewhere once that said itís trying to read the radio security but since itís not tha factory radio it canít read it has anyone else had this problem
Add to Nighthawk42472's Reputation
Rate the quality of this post and help Nighthawk42472 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nighthawk42472 is offline   Reply With Quote
Old 01-27-2018, 03:50 PM   #2
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Default Re: 07 Saturn aura obd2 not working
Check fuses for the OBDII port and double check to make sure you have the correct wiring harness for your vehicle and the aftermarket radio.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 02-04-2018, 03:41 PM   #3
Nighthawk42472
Do you know where the fuse is for OBDII I looked in the fuse box inside the car and under the hood I didnít see one that says OBDII
Old 02-04-2018, 04:09 PM   #4
The L-series OBD II power fuse is labeled CD/DLC (15A), Vues use the AUX 1 (15A), Ions use power from its Lighter Fuse (15A).
Old 02-04-2018, 06:30 PM   #5
explorerbigjon
2008 AURA XE
I have found out that you are looking for the HVAC CTRL (BATT) fuse which is a 10 AMP fuse, it runs the DLC (Data Link Connector for OBDII) and the HVAC control module. The fuse block for that is in the passenger side of the console. Also check the IBCM 1 (30 AMP) fuse in the underhood fuseblock which is connected to the HVAC CTRL (BATT) fuse.
Upgrades coming!
UsingTorque OBD2 on Saturn any custom PID's GTS350 S-Series Tech 3 09-20-2016 08:58 AM
08 Saturn aura door locks not working properly after programming key fob sfreyler Aura General 0 09-12-2016 08:19 PM
Saturn Aura 2009 XR ICP All Gauges not working Havok10 Aura General 2 12-11-2015 03:26 PM
saturn aura 2007 keyless remote not working ole Aura General 3 03-16-2014 01:27 PM
obd2 port not working. wildklymr S-Series Tech 2 09-16-2012 12:00 AM
