Old 01-21-2018, 09:06 PM   #1
Rez
Rez is on a distinguished road
Default Fuel electrical lines
I have a 96 SW2 that was sitting on a property for a while and it has problems surging when it gets around 2000 rpm. I've been troubleshooting a few things, but when I took a look at the fuel system I noticed that an animal had chewed through one of the small electrical lines around the fuel tank. I'm thinking this would cause this issue, no? Any way, my question is what kind of wire can I use to replace the wiring? I don't want to fry anything like the fuel pump as I'm not even sure if I want to put more time and money into getting it running. Thanks!
Add to Rez's Reputation
Rate the quality of this post and help Rez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rez is offline   Reply With Quote
Old 01-21-2018, 09:20 PM   #2
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
Default Re: Fuel electrical lines
The wiring to the fuerl tank would be the fuel level sensor and the fuel pump.
Stranded 18 guage ( copper) can be used to fix anything chewed upon.
My preference is straight crimp connectors, soldered, then heat shrink tubing. In my experience, fix right- once - is preferable to dinking around doing stopgap fixes.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Rusted fuel lines nichitect Ion General 38 01-30-2017 12:04 AM
Diameter of fuel lines rocket321 Vue General 1 08-08-2013 08:44 AM
Fuel Lines for '95 DOHC mjo S-Series Tech 7 07-05-2006 02:58 AM
Fuel Return Air Lines - Where? JS593 S-Series Tech 8 10-28-2005 11:40 AM
Do I need to replace fuel lines W/ fuel Filter? donisaacs S-Series General 2 11-16-2003 08:23 PM
