Old 01-20-2018, 02:55 PM   #1
SIRPAULGERMAN
SIRPAULGERMAN is on a distinguished road
SIRPAULGERMAN's Avatar
Default 185000 miles
Well jut got 185000 miles on the car, after the 2nd alternator the car is working fine, new tires.
I have done the basic maintenance, what else do I need to do to the car ?
When does the Saturn needs new shocks, still on originals the same for the fuel filter ?
Add to SIRPAULGERMAN's Reputation
Rate the quality of this post and help SIRPAULGERMAN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SIRPAULGERMAN is offline   Reply With Quote
Old 01-20-2018, 04:31 PM   #2
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Re: 185000 miles
New fuel filter is advisable. I am at 244k on my 1998 SL2 and am on my 3rd starter, 3rd radiator, 2nd alternator and I rebuilt the suspension at 185K. It wasn't necessary, but it mad the car drive like new.
Really, you only need to replace things as they break on these cars. That's the beauty of driving a Saturn.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 01-20-2018, 04:58 PM   #3
Waiex191
Waiex191's Avatar
I replaced mine at 204,067. It was easy except both bolts snapped off. My kid drilled and tapped new holes.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-21-2018, 12:38 PM   #4
SIRPAULGERMAN
So I dont need to change it ?
Old 01-21-2018, 10:10 PM   #5
Waiex191
Waiex191's Avatar
Probably not. I felt better changing mine due the rebuild. I'll change it again in 2036 or so.
Bryan Cotton
Old 01-22-2018, 12:13 AM   #6
colonelhogan44
Change it. If it is plugged you can go dangerously lean at WOT and may burn a valve.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 01-22-2018, 04:37 PM   #7
TXSaturn02
TXSaturn02's Avatar
I replaced mine at 157K or so ONLY because the 'book' said it was good for 100K. Probably didn't need to - especially if you're not noticing/experiencing any issues.
New owner report of 07/25/18: 229,023 Miles
As of 07/25/18: 51,495 Miles
Old 01-22-2018, 04:46 PM   #8
Highmile
Highmile's Avatar
If you change the filter make sure you buy one recommended here. Wix is prob the best. Cheaper filters can also cause lean conditions at WOT and burn valves.
I ran my original struts about 250k but I replace them when they show signs of being worn. The old bounce test works as good as any for me.
Highmile
'95 SL1 648k and counting
Add to Highmile's Reputation
Old 01-23-2018, 12:38 PM   #9
saturny
saturny has a spectacular aura aboutsaturny has a spectacular aura about
Highmile
Are these lean condition issues only at WOT? Who goes WOT anyway... I don't think I ever have...
2000 Saturn SL1 (w/ DOHC) automatic - 280k
Add to saturny's Reputation
Rate the quality of this post and help saturny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturny is offline   Reply With Quote
Old 01-23-2018, 01:01 PM   #10
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
WOT scares me.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
dummo is online now   Reply With Quote
Old 01-23-2018, 02:56 PM   #11
colonelhogan44
Well, rather than WOT, it's in open loop operation really. While climbing grades in the Mojave desert in the summer, I've watched my PCM drop the engine into open loop many times. Had my filter been restrictive, I could have burned a valve I'm sure.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 01-23-2018, 03:23 PM   #12
Waiex191
Waiex191's Avatar
I don't think I ever haven't! Except for break in.
Bryan Cotton
Old 01-25-2018, 10:01 PM   #13
dummo
dummo's Avatar
1997 SW2
I’m as enthusiastic about WOT as much as I am about keeping an Open Mind. When you keep an open mind, people throw their garbage in it.
Old 01-26-2018, 10:22 AM   #14
Highmile
Highmile's Avatar
Having to pull out from an uncontrolled (no stop light, on ramps, etc) intersection on to a 4 lane divided highway that has a 65mph speed limit... WOT is not uncommon for me.
Highmile
'95 SL1 649k and counting
Old 01-28-2018, 09:02 PM   #15
SIRPAULGERMAN
Any cheap good filter ? they are expensive ? what is WOT ?
Old 01-28-2018, 10:11 PM   #16
dummo
dummo's Avatar
1997 SW2
^^^^ lol - it stands for Wide Open Throttle.
It scares me because it sounds like your nice little car has turned into an angry roaring monster. Not saying I’ve never stomped on my gas pedal before but I’ve had good reason. Well at least at the time I thought so.
Rebuild w/8k miles using 1 qt/800 miles Upstate Saturn S-Series Tech 10 05-31-2015 03:41 PM
100,000 miles! saturn_69 Ion General 38 09-18-2009 10:31 AM
250,000 miles fujioko S-Series Tech 7 06-02-2009 03:38 PM
Most miles ever? clemsonsaturn General Saturn Discussion 36 11-20-2003 08:49 AM
Like New 16" Chrome-Clad L-Series Wheels (4,500 miles) with tires (250 miles) UH2L Classifieds 6 07-07-2003 03:34 PM
