Old 01-20-2018, 01:43 PM   #1
Helimech
Helimech is on a distinguished road
Default 1996 SL2 engine/trans into 1995 SC1
I have a 1996 SL2 donor car with a good engine and auto transmission. Rear subframe is totally rusted out and trailing arm mounts are gone. Can I install the engine and transmission into my 1995 SC1? I realize this is a DOHC drivetrain in the SL2 and the SC1 is SOHC. The SC1 engine is good, but the auto trans blew apart (big hole where parts blew out while driving). The SC1 is pretty much rust free.
Add to Helimech's Reputation
Rate the quality of this post and help Helimech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Helimech is offline   Reply With Quote
Old 01-22-2018, 12:53 PM   #2
Default Re: 1996 SL2 engine/trans into 1995 SC1
Yes, but you will want to bring the PCM over with the SC2 engine and trans.
Probably want t take the instrument cluster, too, as SC2 goes to 130mph, SC1 speedo goes to 110, not sure if that will be inaccurate if you don't bring it over
You'll need to do some research on sensors, wiring harness, etc. '96 is OBDII while '95 is OBDI
maybe this bump will bring out someone who knows
Old 01-22-2018, 05:19 PM   #3
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
The 95 is a bit of an orphan. The electronics are basically gen1. 96 is gen2.
Also - isn't the sc1 TBI?? The PCM and wiring to the injectors would need to be swapped.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 01-22-2018, 05:44 PM   #4
Saturn Night
Make sure to take onlinebiker's advice with chaos' advice, because of the coolant gauge. OBD-II uses one sensor & OBD-I uses TWO. Both engines use an electronic EGR valve, so that shouldn't be an issue.
Old 01-23-2018, 01:23 AM   #5
Keep the '96 exhaust up to the catalytic converter
plug the rear O2 port (leave sensor in if you like)
pull the '95 harness off the SOHC and reattach to the DOHC (swap the knock sensor)
drill & tap 2nd ECTS port in location of your choosing (I like the upper radiator hose nipple, just after the stop tab)
swap PCM to '95 DOHC (can't use '96+ because it's a different harness, same with '94)
Try swapping gauge cluster overlays, if for some reason it doesn't work like I think it should then swap clusters. Either way, the SOHC overlays won't read anywhere near correct on a DOHC.
Transmission:
A) manual can keep whichever you like
B) Automatic have to swap to MP7
'95 is 1st year of the good SOHC's...bye bye to bad sushi (TBI units...lol).
'95 EGR valve is electronic, but like '94's with Cali Emissions it's hacked in (seriously! check out the harness to it, you'll see/feel the hacked in adapter) as it still use's the OBD-1 PCM that doesn't understand non-vacuum EGR signals.
All the injectors '91-'01 use the same connector, sometime in '01.5 to '02 it change's. SOHC injectors won't run a DOHC engine at high RPM for long, they'll go lean fairly quickly and if you're lucky you'll only burn cyl 3 exhaust valve unless you keep the DOHC injectors on the DOHC.
1995 SL1 manual trans: Tough to shift with hot engine osp001 S-Series Tech 3 05-03-2015 11:55 AM
1995 DOHC motor into 1996 SC2 wi111y S-Series Tech 6 11-13-2011 02:10 AM
1996 OBD2 motor in 1995 OBD1 Car osxuser S-Series Tech 6 07-25-2007 01:29 PM
1995 Engine in a 1996 Matt42 S-Series Tech 1 02-18-2007 02:07 AM
WTB: 1995-1996 SC2 in NJ andy_95sl2 Classifieds 1 05-20-2006 02:06 PM
