Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 01-19-2018, 02:30 PM   #1
Reeves98
Reeves98 is on a distinguished road
Default 05 Saturn Ion sedan exhaust
Hey guys Iím new to the forum. Iíve been looking around for a good performance exhaust that will actually fit my 05 ion sedan. Any suggestions or should I look into getting one custom for me?
Add to Reeves98's Reputation
Rate the quality of this post and help Reeves98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Reeves98 is offline   Reply With Quote
Old 01-26-2018, 03:34 PM   #2
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Default Re: 05 Saturn Ion sedan exhaust
There is not too much for the sedans that I have found and going custom allows you to mix and match your own muffler into a system. ZZP has some for the redline but those would need to be extended to fit ours a bit. That system with a resonator is $480 but most shops should be able to make something for less than that but it might not be mandrel bent like the better performance ones are or stainless. Depends how long you plan on keeping it and what you want out of your exhaust. ZZP also sells headers and down pipes if you wanted the whole system to be 2.5 inch.
2004 Saturn Ion CAI, Aftermarket Headlights and Taillights, Bluetooth Fogs, ZZP 2.5" Cat and Custom 2.5" Complete Exhaust
2000 F150 Off-Road 3" Duals and K&N Intake
2013 Escape 2.0T AWD CAI
Add to WrightMan's Reputation
Rate the quality of this post and help WrightMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrightMan is offline   Reply With Quote
Old 01-30-2018, 10:23 PM   #3
Clyderp
Clyderp is on a distinguished road
2007 ION-2 Sedan
I have a full ZZP 2.5 inch exhaust on my 07 sedan. The catback fits all the hangers correctly, but the tip hangs out quite far and low. I ended up cutting out a few inches of the pipe before the muffler and modifying the hanger and the tip sits how I like it now.
Add to Clyderp's Reputation
Rate the quality of this post and help Clyderp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Clyderp is offline   Reply With Quote
Old 01-31-2018, 12:07 PM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
like others mentioned, ZZP sells aftermarket exhausts.
a cheaper option would also to find someone selling a redline exhaust, or from an ion with a 2.4, basically the same thing.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Will wagon exhaust fit a sedan? Midnight13 S-Series Tech 3 08-16-2012 10:39 PM
2000 SL Sedan - Exhaust help! Beryle S-Series Tech 5 09-20-2008 06:31 PM
2004 Sedan Exhaust cornutt Ion Mods 3 09-08-2008 09:19 AM
Ion Sedan Exhaust options? jdubzy Ion Mods 7 07-04-2007 06:01 PM
Loaded ION 3 Sedan vs. Base L300 sedan Caprice General Saturn Discussion 32 02-26-2004 03:29 PM
