Old 01-18-2018, 10:18 PM   #1
twernicke
twernicke is on a distinguished road
Default Exhaust Manifold to head pipe question
I'm going to be replacing the head pipe and converter for my son's 2002 SL1. I have the pipes and gaskets but not sure what I might need to bolt it up to the exhaust manifold. Does it have (3) bolts/nuts or are there (3) studs coming out of the manifold. I don't have the car here right now to look, just trying to make sure I have all of the parts that I need. Thanks!
Add to twernicke's Reputation
Rate the quality of this post and help twernicke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twernicke is offline   Reply With Quote
Old 01-18-2018, 10:52 PM   #2
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Default Re: Exhaust Manifold to head pipe question
There should be three studs with nuts, 13mm hex. I wouldn't try it with anything other than a 6-point socket. A 12" extender and universal-joint are also helpful. 3/8" drive on all, not enough room for 1/2". I don't think a deep socket is mandatory, but may also be helpful.
Add to billr's Reputation
Old 01-18-2018, 11:04 PM   #3
twernicke
OK so the studs are pressed into the manifold?
Old 01-18-2018, 11:23 PM   #4
No, they are screwed into the manifold. Use an impact wrench and the nuts will come off or the stud will screw out of the manifold. Buy a good battery impact.
Help with Exhaust Manifold to Down Pipe Studs and Nuts bachands S-Series Tech 10 05-29-2018 08:57 AM
What is the AIR pipe on the exhaust manifold? linearbit8 L-Series Tech 29 05-16-2014 11:57 AM
Removing front exhaust pipe from manifold, V6 cityhawk L-Series Tech 1 05-23-2012 01:42 AM
JB Weld covered exhaust manifold pipe Digger02 S-Series General 1 04-18-2012 02:20 PM
How to Remove Stud (Manifold to Exhaust Pipe) MickSaturn S-Series Tech 15 01-28-2007 02:25 AM
