Old 01-18-2018, 01:42 PM   #1
gerald.jones77
gerald.jones77 is on a distinguished road
Default Saturn Fuel Pump and Line Replacements
Model: Saturn 1998 sl2 auto
my car started having intermittent stalling which rapidly got worse, changed crank sensor and coil pack. So, I started taking out fuel pump, the fuel pump had different fittings on the arms so I took it back and also, I broke one of the plastic elbows on the fuel line right where it joins with the fuel filter. I'm reading I have to replace whole fuel line but I'm also seeing that the piece can be replaced. It's just a small plastic elbow, i don't see why I can't just take it out and fit a new one in,and also, I need the connector from the gass filler neck to the gas tank, does anyone know where to buy these? so...
Problems: 1. Fuel pump with different attachements than the one that I'm taking out.
2. the broken elbow on the fuel line.
3. the connector fitting, right at the end of the gas filler neck, where can I buy it? Thank you for all responses.
Add to gerald.jones77's Reputation
Rate the quality of this post and help gerald.jones77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gerald.jones77 is offline   Reply With Quote
Old 01-18-2018, 02:15 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Saturn Fuel Pump and Line Replacements
Whereabouts do you live?
Have you visited your local autoparts stores? NAPA might have something.
Unless someone here has something spare on their garage shelf, otherwise, visit a JY.
Old 01-18-2018, 02:30 PM   #3
gerald.jones77
i'm in seattle, i've thought about jy but then i'd have to take the parts off. a connector shouldn't be too expensive and i have a different pump on the way as well as a fuel filter.
Old 01-19-2018, 01:05 AM   #4
Fuel system with blown up diagram and part numbers, if it's something still supplied there's a price as well: https://www.wholesalegmpartsonline.c...riveLine=11480
If it's just nipples/connectors you need...goto the local hardware store with the pipe size and get a few brass ones as well as a few clamps. If it's the hard plastic line then you'll have a heck of a time getting the old connector out and the new connector in without destroying it.
Old 01-20-2018, 06:45 PM   #5
gerald.jones77
If it's just nipples/connectors you need...goto the local hardware store with the pipe size and get a few brass ones as well as a few clamps. If it's the hard plastic line then you'll have a heck of a time getting the old connector out and the new connector in without destroying it.[/QUOTE]
I've seen vids online use boiling water and/or hairdryer.
Saturn SC2 with P0171. Replaced Fuel Pump and Fuel Filter. Natelancer S-Series Tech 13 03-16-2017 05:13 PM
96 Sl1 Fuel Pump Line Only Hockey S-Series Tech 0 01-26-2016 02:15 PM
94 Saturn Fuel line problem..... goon S-Series Tech 30 10-19-2015 08:34 AM
Multiple Fuel Filter Replacements Skelaton44 S-Series Tech 13 06-28-2013 02:02 PM
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 06:42 PM
