Old 01-18-2018, 12:30 AM   #1
Alex707
Alex707 is on a distinguished road
Default Ls1 Saturn 2001 ignition wonít engage after turning the car off
HELLO IM ALEX
I OWN A 2001 SATURN LS1 ECONOMIC AUTOMATIC
30,000. MILES
THE CAR ONLY COST ME A FEW HUNDRED DOLLARS
IT GOT A TUNE UP AND NEW TIRES
THE CAR WILL START ONCE A DAY...
IT WILL RUN FINE AND SAVES ME GAS
ONCE THE CAR IS TURNED OFF THE F**k IT WONT TURN BACK ON
I WAS TOLD THAT THE KEY IS BAD BECAUSE ITS NOT THE ORIGINAL
I CHECKED THE IGNITION CONTOL MODULE BUT IT STARTED DOING THE SAME
NOT SURE WHATS GOING ON WITH MY SATURN
I MIGHT HAVE TO TAKE IT INTO THE DEALER SHIP.
Add to Alex707's Reputation
Rate the quality of this post and help Alex707 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alex707 is offline   Reply With Quote
Old 01-18-2018, 01:40 AM   #2
pierrot
pierrot's Avatar
Default Re: Ls1 Saturn 2001 ignition wonít engage after turning the car off
Originally Posted by Alex707 View Post
HELLO IM ALEX
Welcome to SaturnFans, Alex! Thank you for adding your vehicle information beneath the login name. At present it shows that you have a 2001 SL1. However, your message says you have a 2001 LS1. First of all, the LS1 model name existed only for model year 2000. From 2001 onwards the model designation changed to L100, or L200, or L300 for sedans.
Please correct the information. Is the car an S-Series (1.9L), or L-Series vehicle (2.2L four cylinder, or 3.0L V-6)? BTW, "ECONOMIC" was not part of any formal Saturn vehicle or engine description. What are your referring to?
302,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 01-18-2018, 10:33 AM   #3
Alex707
Sl1
Sl1
Itís the sl1
I just went out to start the car and it turned on
I turned it off
I turned it on fired up
I turned it off
Third time it fires up, the car started
Then I turn the car off
I turned the key but the car didnít even crank the starter.
Old 01-22-2018, 12:52 AM   #4
You might be better served by reposting in the S-series Tech forums as your problem isn't going to be answered quickly......... where more members with the same model as yours may contribute help.
2001 Sl1 slams into second gear and occasionally doesnt engage into drive Mikesutch S-Series General 3 04-11-2016 03:20 PM
2001 Saturn SL2 new ignition cylinder Help gbc_15 S-Series Tech 1 01-27-2013 05:01 PM
98 SL2 Ignition key not turning dbert513 S-Series Tech 3 02-04-2012 09:58 PM
2001 L300 V6 a/c clutch won't engage hypnotize83 L-Series Tech 7 08-08-2011 08:57 AM
2001 SC2 5sp - A/C Compressor won't engage ambradley S-Series Tech 4 05-01-2011 05:07 PM
